Go Back   Subaru WRX Forum: WRX Forums > WRX Tech Forums > Bolt-on Tech (EJ255/EJ257 2.5L '04-07 STi and '06-07 WRX)
Old 03-31-2009, 07:32 PM   #1 (permalink)
boostspike's Avatar
Reputation: boostspike is more helpful than not
oil pressure numbers?
anyone have any oil psi numbers like when its warm at idle, driving at highway speeds i just want to compare?
Old 03-31-2009, 08:45 PM   #2 (permalink)
c2bcoolwrx's Avatar
Car: 05 WRX
Club Region: Southeast
Reputation: c2bcoolwrx is more helpful than not
warm/idle: 40-50 PSI
highway speeds: 75-80 PSI
Those numbers are right where my engine builder/tuner and I want them. However, my engine (EJ257 Hybrid) is far from stock so your ideal numbers maybe a little different.
If you want more numbers or more exact ones, I can do a more thorough check when I go out tomorrow.
Old 04-01-2009, 09:06 AM   #3 (permalink)
boostspike's Avatar
well mine are
70-80psi warm at highway speeds
but only about 20-25psi warm at idle sometimes as low as 15psi on really warm days
is that too low for a 2006 wrx with almost 80,000
Old 04-01-2009, 07:16 PM   #4 (permalink)
VD5505's Avatar
Reputation: VD5505 is known to be trustworthy and helpful VD5505 is known to be trustworthy and helpful VD5505 is known to be trustworthy and helpful
the rule of thumb with oil pressure is 10psi for every 1,000 RPM's, remember that to much oil pressure is a bad thing as well. When you see after market oil pumps you are looking for high volume since a pump doesnt make pressure it makes volume.
Old 04-12-2009, 01:38 AM   #5 (permalink)
midniteblack's Avatar
Club Region: Southwest
Reputation: midniteblack is more helpful than not
Send a message via AIM to midniteblack
my #'s are right around where yours are boostspike. and around 100-120ish full throttle.
Old 04-12-2009, 06:21 AM   #6 (permalink)
VD5505's Avatar
That is alot of oil pressure.
Old 04-12-2009, 07:55 AM   #7 (permalink)
Trader Rating: (3)
I also max out my 100psi gauge at full rpm..
