Go Back   Subaru WRX Forum: WRX Forums > WRX Tech Forums > Bolt-on Tech (EJ255/EJ257 2.5L '04-07 STi and '06-07 WRX)
Old 06-23-2009, 07:19 PM   #1 (permalink)
Schmidtastic's Avatar
Club Region: SoCal
Reputation: Schmidtastic is an unknown
New injectors?
Hey guys, just a quick question. When i go to stage two with my 04 sti will i need new fuel injectors? I was gonna get new ones anyway just wondering if when i went stage two i needed to do the injectors at the same time, and what kind of injectors should i get? Thanks in advance
Old 06-23-2009, 07:55 PM   #2 (permalink)
Ask your tuner. For stage 2 not really. And the size of injectors depends on your turbo, your tune all that stuff, but heres a reference:WRX Fuel injector sizing guide STi Fuel injector sizing guide Lgt fuel injector sizing guide, JSC Speed
Old 06-23-2009, 08:15 PM   #3 (permalink)
Club Region: SoCal
Thanks man. And its for stock turbo with hks cbe, helix catted high flow downpipe, with the cobb accessport. Just wanted to know what a good brand would for the injectors
Old 06-23-2009, 08:48 PM   #4 (permalink)
Well my tuner suggested the deatchwerks ones. If you do go with bigger injectors, get ahigh flow fuel pump also.
Old 06-23-2009, 09:33 PM   #5 (permalink)
Timeslip: 9.999 @ 101.26
You do not need bigger injectors for stage 2. Keep the stockers until you upgrade the turbo.
Old 06-23-2009, 09:53 PM   #6 (permalink)
Not needed, but getting a fuel pump and injectors you can max out your stock turbo. Thats your call.
Old 06-23-2009, 10:27 PM   #7 (permalink)
Club Region: SoCal
If i get a fuel pump do i also need the injectors or am i good with just the fuel pump?
Old 06-23-2009, 11:46 PM   #8 (permalink)
You don't need either right now. Nor for stage 2 and yes you could get the fuel pump without the injectors.
A good rule of thumb is if you need a fuel pump to run your mods safely you are close to maxing your injectors but once again you don't need it for stage 2 which is what your asking correct?
Old 06-24-2009, 12:00 AM   #9 (permalink)
Club Region: SoCal
Yes sir thats what i was asking. Cause i read somewhere that for stage 2 it would be a good idea to get a new fuel pump. So for stage 2 i wouldnt need either new injectors or fuel pump unless i upgraded the turbo?
Old 06-24-2009, 12:17 AM   #10 (permalink)
Correct. The only STi's that ive read about going with a fuel pump for stage 2 are some of the 07 STi's that's the year when stock maps were crappy.
Old 06-24-2009, 01:09 AM   #11 (permalink)
Club Region: SoCal
Aight thanks guys its much appreciated
Old 06-24-2009, 09:03 AM   #12 (permalink)
Not exactly "stage 2" but my tuner did believe that the stock turbo is limited by the stock STi injectors. If you're getting a protune, you might consider it even with the VF39/43 still under the hood. Being fuel limited is a waste For a cobb AP stage 2 map do you need upgraded injectors? No. In fact, you can't use that map if you did.
16G powered lagless fun
