Need help to determin the path of my STi - Page 2 - Subaru WRX Forum
post #16 of 49 Old 10-04-2010, 08:41 PM
they probably do, but the only way to be safe with meth is to have a standalone that works with the meth kit to protect against failure
post #17 of 49 Old 10-04-2010, 10:49 PM
Yeah, your going to need as much fail safes as possible or reasonable. I'd listen to matt. Stand alone ECU or don't bother touching meth.
post #18 of 49 Old 10-04-2010, 11:51 PM
Totally agree. The system needs to be able to cut timing immediately if there is a problem to properly protect your engine. AEM is one of the few that can do that, but you have to use their standalone. It's a good product for other reasons too, just expensive. Just don't half ass it.
post #19 of 49 Old 10-05-2010, 12:01 AM Thread Starter
well there is a built in fail safe, so that if it runs out it will shut down or at a certain boost level it will cut off and go to a lower boost setting. this is the only system i feel comfortable with using not only because its inexpensive but of the quality of the product. ill be sure to double check with aem and email them about running there meth kit with there stand alone ecu. but other than that i still need to find a 400whp turbo that spools fast yet can still blast power from way down low to redline.
Keshav (kay-shuv)
stage II pro-tuned 04 STi
294whp/343wtq VF39 @19psi
srninjastar is offline
post #20 of 49 Old 10-05-2010, 06:32 AM
The boost cut is an option but I still wouldn't trust it, meth doesn't really let you run more boost it's the timing that makes the power. As for your turbo desires that doesn't really exist in the subaru world...anything that makes 400awhp won't spool until about 3700-4200 RPM
post #21 of 49 Old 10-05-2010, 07:40 AM
and if you really don't want to go standalone and use meth I would definitely go with the Snow Performance kit just because you can upgrade to this Snow Performance: SafeInjection? when combining with this http://www.jandssafeguard.com/safeguard.html
post #22 of 49 Old 10-05-2010, 09:42 AM
Not entirely true. It cools the charge down considerably... My IAT's were down 70-80* in the summer at full boost... I was able to run 4-5lbs more without pulling timing. And the AEM kit I have does have a 2 way controller so you can make it progressive or non.
The safety on it worked very well. When the alarm went off.... I just didn't mash it for the rest of the day (or home if I was heading there)
A one gallon 50/50 mix can last as long as you want it to (within reason)
I had a gallon lasting 2 weeks at a time.... and that's actually USING it.
They are made alot safer than previous years...
Then again... I don't do the tuning myself... just the install and running
post #23 of 49 Old 10-05-2010, 09:49 AM
I mean yes you can run more boost, but the amount you'll be running is typically out side of the turbos efficiency range so really your just making more heat and yes it'll screw things up but the real danger lies in the extra 4-5* of timing meth allows you to run
post #24 of 49 Old 10-05-2010, 10:05 AM
Yeah... thanks for the corrected wording Matt.
Another thing to add.... You can have seperate maps for daily and "spirited" driving.... So all in all as long as you are a type of person that is always on top of things.... It's fun and safe.
COBB in Plano didn't want to hook up the meth on my MS3.... "safety" is what they quoted me.
post #25 of 49 Old 10-05-2010, 07:53 PM Thread Starter
so ive decided to go with the FP green turbo. relatively inexpensive and will provide me with more than enough power once i get an ewg and possibly meth on with the tune. now i just gota start saving...
Keshav (kay-shuv)
post #26 of 49 Old 10-05-2010, 08:35 PM
just be warned...the Green spools kind of sluggishly...~4000 RPM
post #27 of 49 Old 10-05-2010, 09:16 PM Thread Starter
i was under the impression that the FP Red was the turbo that spooled slow
Keshav (kay-shuv)
post #28 of 49 Old 10-05-2010, 09:20 PM Thread Starter
wait nvm im getting the blouch dom 2.0 haha. thats what i want. final answer...
Keshav (kay-shuv)
post #29 of 49 Old 10-05-2010, 09:36 PM
You realize that your engine will definatly need piston work if nothing else. Plus, the Dom 2.0 will spool slower than my turbo. Which mine spools later than the VF39. But, it its the crank hp numbers your looking for.
I hope to see improved numbers in a short bit when I go back. Plus, the spool might be faster once its cooler out. The heat and humidty really screwed me last time. With a few changes in my set-up and cooler air....I should be putting down what the Dom 2.5 XTR is capable of. If my tuner ever gets around to making the Dom 3.0 twin scroll...I might be tempted to cross over to the dark side. lol.
post #30 of 49 Old 10-05-2010, 09:52 PM Thread Starter
well its just the regular dom 2.0 but i have the option of having a 8cm^2 turbing housing or a 10cm^2 turbine housing. which should change the responsiveness of the turbo right? cause to be honest i have no freakn idea by what they mean when they provide those numbers and what it relates to lol.
yea i am looking for nice crank numbers but also i dont want to have to wait for my turbo to spool up. just want more low to mid range power but a bit more air up top than the stock turbo. not asking for some super snail that will get me from 0-100 in 2 seconds. just enough to get my head jerkn in the back of my seat.
Keshav (kay-shuv)
