Need help with 06 wrx turbo - Subaru WRX Forum
post #1 of 2 Old 03-17-2017, 02:30 PM
DarthnVadeHer
Guest
Posts: n/a
I recently bought an 08 wrx td04 turbo thinking it would be the exact turbo as the oem 06 one. I recently found out that it wasn't. My question is that.. do I need to upgrade anything if I do put it in my car? Currently have Cobb stage 1 tune, aem short ram intake, and a catback. The rest is stock.
post #2 of 2 Old 03-17-2017, 03:16 PM
Ruso's Avatar
Ruso is more helpful than not
The 08 turbo has a completely different compressor outlet configuration. It points up and has a flange that connects to the LGT style intercooler which is designed to go to to the new plastic style manifold. The 06 td04 does not have a flange but has a silicone hose type connection.
On top of that, the 06 turbo is a td04-13t but the 08 is td04-19t which is a bigger turbo that makes just a little bit more power.
So simple answer is, unfortunately no, it won't fit onto your car without pretty significant modifications to your intake path.
td04-13t (02-07 wrx)
td04-19t (08 wrx/LGT/FXT/OBXT)
Ruso is offline
