Old 06-28-2008, 07:25 AM   #1 (permalink)
Club Region: Gulf Coast
Reputation: pzr2874 is an unknown
MSD coilpacks
Anyone know if changing these out will help my spark. Worth the $ ?
2007 WRX
Old 06-28-2008, 09:37 AM   #2 (permalink)
Any OEM coil on plug ignition is actually pretty good.I spent alot of time reading/researching about ignition upgradeds and the WRX's coils are good for around 60K volts (not sure the joules).You really don't need to upgrade unless you have a built block and will be running over 25+ psi.Basiclly only high boost applications have a problem with spark blow out so ignition upgraded might be worth it then.You can get some better performance by playing with sparkgaps and better grounding.I belive the coilpacks use the bolt that holds them on as thier ground.
Aarg matey!
ECU Pirated by RomRaider
Old 06-28-2008, 11:29 AM   #3 (permalink)
Thanks Ron
2007 WRX
« help | Headers »
