most of my new toys. - Page 5 - Subaru WRX Forum
post #61 of 73 Old 09-18-2007, 06:28 PM
I want an update
post #62 of 73 Old 09-18-2007, 08:59 PM Thread Starter
Jave's Avatar
Jave is more helpful than not
I just got the break in period over with. waiting on my wideband to come in so I can let Tim start bringing her to life. I did a log earlier and this turbo sounds pissed off when you get to 5k and up. I let out of it at 6k but she had plenty of pull. I cant wait.
I also noticed a slight chirping noise on startup. It goes away after the car is up to temp but still bothers me. It seems to be coming from the drivers side of the engine towards the front so it might/better be a pulley.
▼SbiΣ Mi▼
Jave is offline
post #63 of 73 Old 09-18-2007, 09:09 PM
sweet...hope its just a pully/belt
post #64 of 73 Old 09-19-2007, 01:38 AM
sounds like its an a/c belt. :crosses fingers:
Robby
02 rex is gone.
I defected to an evo :)
Evo is gone :(
Now I got nothing.
WRXKidid775 is offline
post #65 of 73 Old 09-28-2007, 01:35 PM Thread Starter
Jave's Avatar
I figured I would update everyone on how everything is going. First off the mystery noise is not the AC or altenator belt so I removed the timing belt cover and discovered the belt had more slack in it than when we put it back together. The is a brand new kevlar reinforced belt so it could not have stretched so it must the be tentioner. I have already pulled the belts off but need another person to hold the brake to get the crank pulley off. Then I will be able to mark the belt and stat ording more parts.
On the good side, this setup is a beast. I have tons of power and then the turbo spools.
I made a few 3rd gears pulls for logging and wow I thought that the turbo was doing good at 4k but after 5k-5.5k it really sets me back. Sadly I need to fix the the tensioner first before I continue logging.
▼SbiΣ Mi▼
Jave is offline
post #66 of 73 Old 09-28-2007, 05:40 PM
At least you found the problem and its a relatively easy fix. Good luck with it all.
post #67 of 73 Old 10-17-2007, 12:57 PM Thread Starter
Jave's Avatar
I finally discovered what the noise actually was. Turns out the drivers side intake cam gear was rubbing on the back timing belt cover. That would make sense becuase the noise is only there when the weather is cold/car cold but goes away if the weather is warm and the car is warmed up. Spray some dry lubricant behind it and noise goes away instantly.
▼SbiΣ Mi▼
Jave is offline
post #68 of 73 Old 10-23-2007, 04:09 PM
Glad to hear. Did you get the e-mail tune, yet?
post #69 of 73 Old 10-23-2007, 05:28 PM Thread Starter
Jave's Avatar
I was able to finally log it and send it to Tim, he got back with me and said things looked pretty good but for some reason my LC-1 isnt logging correctly so I need to get that fixed before we can fine tune it.
▼SbiΣ Mi▼
Jave is offline
post #70 of 73 Old 10-29-2007, 03:59 PM
Well, let us know.
post #71 of 73 Old 10-29-2007, 05:27 PM
WRXforME's Avatar
WRXforME is an unknown
Damn Jave... our cars look so similar
WRB, cleared headlights, SSAuto FMIC... Only diff is my front lip.
How much power do you expect to make with that setup?
How much boost are you going to be running?
WRXforME is offline
post #72 of 73 Old 10-29-2007, 07:27 PM
so let's recap, sz 49 turbo, and sti shortblock and of course all supporting mods, we all wanna see that thing in action. lol. im sure u do too. u should be close to 400whp i think.
post #73 of 73 Old 10-29-2007, 10:22 PM Thread Starter
Jave's Avatar
Tim has my first usable log so we will see after I get a few more fine tuning adjustments. He said that everything looks really good for as many mods I have added, just a tad rich across the board.
▼SbiΣ Mi▼
Jave is offline
