most of my new toys. - Page 3 - Subaru WRX Forum
post #31 of 73 Old 08-02-2007, 12:17 PM
god bless subaru for little details like that. Good Luck!
post #32 of 73 Old 08-02-2007, 12:39 PM Thread Starter
Jave's Avatar
Jave is more helpful than not
after what I have been through with this so far, I will need every ounce I can get.
▼SbiΣ Mi▼
Jave is offline
post #33 of 73 Old 08-03-2007, 04:49 PM
nice wheel btw... get bit by the GT4 bug too?
post #34 of 73 Old 08-03-2007, 09:21 PM Thread Starter
Jave's Avatar
no that is my room mates.
I was able to get the heads on today with minimal blood pressure issues. Well after I swapped the buckets around. It amazes me that I pay a shop to assemble the heads so all I have to do is pull the cams and bolt the heads on and reinstall but no. ANyways they set the intake buckets in the exhaust and vice versa. It all good now though.
▼SbiΣ Mi▼
Jave is offline
post #35 of 73 Old 08-04-2007, 08:23 PM Thread Starter
Jave's Avatar
got the engine stabed after a few mishaps. My dad bolted the up pipe on upside down and we forgot to install the shifter fork before bolting the tranny to the engine. So we have a lot to go but we are miles ahead of where I was a few days ago.
▼SbiΣ Mi▼
Jave is offline
post #36 of 73 Old 08-06-2007, 12:35 AM
MTL79's Avatar
MTL79 is an unknown
Wow man, good luck.... should be sweet!
MTL79 is offline
post #37 of 73 Old 08-13-2007, 12:24 PM Thread Starter
Jave's Avatar
So the latest installment in the disappointment of my life is.....
Car is still not running. I did however get lots of small things out of the way. Some bad things did happen as well,left a coolant return line off of the head and I cant get the banjo bolt started without the UP-pipe removed. So we decided we could just take the 2 bolts loose from the up pipe and fix it in under 15 mins. 4 hours later we decide to call it quits with the he discovery that the O2 sensor wire being cut just above the sensor it self(tried soldering it back but for some reason the solder didnt want to suck into the wire), and notbeing able to get 1 of 2 bolts out of the UP. I know we used anti seize but for some reason there is no way to get it broke loose. It doesnt help that we have to use a wobble joint to get to the bolt so it looks like I will be removing a motor mount and jacking the engine up to get better access.
If I would not have wasted my afternoon on this 1 bolt I chould have been running.
▼SbiΣ Mi▼
Jave is offline
post #38 of 73 Old 08-13-2007, 05:26 PM
just take a moment to check all the feed lines twice before running it. Oh the nightmares that can save...
post #39 of 73 Old 08-13-2007, 06:27 PM
Man, That sounds awesome...I'll definatly have to check back to see how this turns out. I pray its good, Jave.
post #40 of 73 Old 08-14-2007, 01:09 AM
your almost there man. think of it this way. with how long its been taking if youve been saving youl be that much closer to the ppgs
Robby
02 rex is gone.
I defected to an evo :)
Evo is gone :(
Now I got nothing.
WRXKidid775 is offline
post #41 of 73 Old 08-14-2007, 09:50 PM
Man alot been going on since I have been gone, wish I could visit here more regularly, the depployemnt dont help. But what an awesome build, good luck with everything man. Cant wait to see the final result of the beast.
post #42 of 73 Old 08-14-2007, 11:42 PM
wrxman420's Avatar
With all the problems your having, you might as well send me all those parts and ill put them on my rex!! lol jk. Hopefully it all works out, i wanna see some #'s for this setup.
wrxman420 is offline
post #43 of 73 Old 08-15-2007, 01:01 AM Thread Starter
Jave's Avatar
lol yeah, I only have time to work on this during the weekend. Couple that with the fact that I dont have any shade to work in with it being over 100, it really sucks. Even though I ahd a few set backs with the build(not counting getting the heads corrected or getting the right prats due to incompentance) I am still learning loads and hopefully everything will work out in the end. Thank you all for the intrest you have show in one shade treeless mechanic.
▼SbiΣ Mi▼
Jave is offline
post #44 of 73 Old 08-26-2007, 07:12 AM
WRXforME's Avatar
WRXforME is an unknown
Well Jave....?
We are all still waiting damnit :P
WRXforME is offline
post #45 of 73 Old 08-26-2007, 10:32 AM Thread Starter
Jave's Avatar
All I have to say is DAMN! I only have 40 miles on it and it is a beast even if I cant boost it yet. Wastegate on this tiny turbo I am running sounds like a damn chipmunk and gives me wood every time I run it up close to boosting. Smoking is almost non exsistent now and I cant wait to get my 1000 miles break in over with to start logging and getting it fine tuned. Later today I plan on washing ans waxing to get some pics, especially of the engine bay.
▼SbiΣ Mi▼
Jave is offline
