Go Back   WRX Forums > WRX Tech Forums > Bolt-on Tech (EJ255/EJ257 2.5L '04-07 STi and '06-07 WRX)
» Sponsor Links
»Garage Storage and Cabinets
Old 05-05-2006, 10:00 AM   #1 (permalink)
Club Region: Southwest
Reputation: 06Scooby is an unknown
manual boost controller
ok heres a question for u guys, last nite i installed my boost controller had is set up at 15-17 psi.... when under a load at full boost i threw a check engine light along with the flashing cruise light. i checked the codes and had a wastegate performance code, took the boost controller off and had no problems.. anyone run into this before? thanks
b
Old 05-05-2006, 12:03 PM   #2 (permalink)
need2boost's Avatar
Reputation: need2boost is an unknown
b
not yet, my MBC comes in today, they say not to use MBC's because of part throttle full boost which causes the engine to run lean without proper EM but i have a cobb stage II so i see partial throttle full boost anyways, I'll let you know if my MBC throws a code. i to plan on setting it at 15-17psi
Old 05-05-2006, 09:02 PM   #3 (permalink)
Ian
Ian's Avatar
Car: 04 WRX
Send a message via AIM to Ian
That your cars way of saying it doesn't like what your doing! Get rid of it and get your car tuned properly.
Old 05-05-2006, 09:23 PM   #4 (permalink)
Jag_Warrior's Avatar
Reputation: Jag_Warrior is an unknown
Boost Controllers and You...
If you decide to part those cars out after you blow them, I'd be interested in the brakes. I like the '06 brakes.
No sympathy from me. It's a big azz sticky at the top of the Newbie page. But, but, but... my car is different. Like I said, I'll bid on the brakes when you part them out.
Old 05-05-2006, 11:06 PM   #5 (permalink)
awd>fwd's Avatar
Reputation: awd>fwd is an unknown
That is your car yelling at you. Good way to kill the motor.
Brent
Cool people have coilovers.
▼SùbiΣ Mäƒiä▼
Old 05-06-2006, 03:36 AM   #6 (permalink)
9d2TSi's Avatar
Trader Rating: (4)
Look guys, it's pretty simple. Ditch the mbc's. Most engine management will control boost for you using the stock bcs, this is the safest way of doing it.
You guys are on the fast track to destroying your engines.
Consider yourselves warned.
P&L tuned 2007 WRX TR
301 awhp / 337awtq
It's like 10 lbs of shit in a 5 lb bag...
Old 05-06-2006, 11:44 PM   #7 (permalink)
Car: 05 WRX
Reputation: Black Night is an unknown
Send a message via AIM to Black Night
personal experience....i had my boost set to 17 psi....i was racing my friends RSX type S frum a roll doin about 75-80 in third gear half throttle but full boost....my car bucked, made a popping noise and threw a CEL...in otherwords...Knock Knock....ditch the MBC
Old 05-07-2006, 01:55 AM   #8 (permalink)
awd>fwd's Avatar
Street racing is cool YO!
We have all been there, but we grow up sometime..
Brent
▼SùbiΣ Mäƒiä▼
Old 05-07-2006, 04:47 PM   #9 (permalink)
need2boost's Avatar
i have my MBC, installed it, set at 17 psi, works fine, no codes, no ill effects. car pulls at 17psi to about 5500rpm then the turbo isn't big enough to hold the psi to redline, when i get my 18g that shouldn't be a problem. i plan on running 20psi with a pro-tune, not saying that everyone should get one, just saying that I'm very pleased with it.
Old 05-07-2006, 05:19 PM   #10 (permalink)
You're going to get a pro-tune when you get the new turbo? So... you aren't running any sort of aftermarket engine management now? 17 psi on an '06 with no (revised) EM. How much over stock is that on the '06... 3.5 psi or so? How long have you been doing that?
Old 05-07-2006, 08:44 PM   #11 (permalink)
awd>fwd's Avatar
Are you doing a science experiment?
"How long will my 2006 WRX's motor last at 20 pounds of boost and no engine management."
Not long.
Have fun.
Brent
▼SùbiΣ Mäƒiä▼
Old 05-08-2006, 12:40 AM   #12 (permalink)
Car: 05 WRX
yeah i cudnt resist racing him ### i knew i had him...but lemme tell u it is not fun wen that stuff happens
Old 05-08-2006, 01:50 PM   #13 (permalink)
need2boost's Avatar
well i plan on getting a protune when i get my 18g, and I'm running 16.7psi according to my (AP) so thats about 1.7psi more than the targeted boost. been running this since Friday, have logged it many runs to make sure my o2 reading are not lean, and I'm not getting any knock. The car feels very smooth. The main reason i have A MBC is to hold my targeted boost. otherwise i was running 1-2psi short of my target boost levels. MY engine isn't going to mysteriously blow up because I'm using a MBC set at 1.7psi higher than stage II.
Old 05-08-2006, 01:54 PM   #14 (permalink)
need2boost's Avatar
Not long.
Have fun.
who said anything about running a MBC set to 20psi, with no EM. my car is set to 17psi. with EM and has been logged, again i say my motor isn't going to mysteriously blow up because of a MBC, not a NOOB I know how to log and check my work.
Old 05-08-2006, 11:14 PM   #15 (permalink)
Sorry, I guess I missed the part of your first post where you mentioned you were running AP. Still, sounds like an "interesting" approach. Good luck with that.
