Loosing Boost Pressure - Subaru WRX Forum
post #1 of 4 Old 01-25-2008, 11:26 AM Thread Starter
GoWRXGo's Avatar
GoWRXGo is an unknown
Send a message via AIM to GoWRXGo Send a message via Yahoo to GoWRXGo
Hey guys, I recently RE-Flashed a friends 07 STI with a 91 Octane Daily Driver Map using my Tactrix cable. Everything was great, he hit target boost (16lbs), car ran like a champ.
So, he calls me this morning and says that while boosting yesterday, it fell from 16lbs to
9lbs. Even at WOT in 3rd and 4th 9lbs. I told him that maybe the car went into limp mode for some reason. The car has a Perrin BOV and nothing else, so I told him to remove the BOV and replace with stock and run again.
Any thoughts??
-Jay
-Opensource Apprentice-
GoWRXGo is offline
post #2 of 4 Old 01-25-2008, 07:47 PM
b7g
b7g's Avatar
b7g is an unknown
if it worked well in the beginning after the flash with the bov, then it is probably the ecu readjusting/compensating for something within the map (i am ony getting into opensource, so take it as a suggestion). Maybe he did some other bolt-ons. Tell him to reset the ecu, it should go back to its original flshed behavior and will relearn and compensate to how it's acting now after some time. Hope this is of some help...
drive = freedom
b7g is offline
post #3 of 4 Old 01-25-2008, 08:14 PM Thread Starter
GoWRXGo's Avatar
I told him to reset the ECU and he did, the car runs fine now. What happened??
-Jay
GoWRXGo is offline
post #4 of 4 Old 01-26-2008, 09:53 AM
SWFL Scooby's Avatar
SWFL Scooby is an unknown
The BOV was most likely the culprit. Boost that is supposed to be recirculated was not causing an extremely rich MAF reading.
D-Rock
Under constant pressure
SWFL Scooby is offline
