just starting - Subaru WRX Forum
post #1 of 15 Old 05-01-2008, 03:30 AM Thread Starter
ibyu4dola is an unknown
just starting
i installed the invidia v3 divorced wastegate dp on my 04 sti about a month ago. it made a pretty big difference but don't know what to go for next. either up-pipe or cbe. i was thinking invidia n1 race exhaust but was wondering if anybody knew the hp gains from those 2 together or if it was too loud. other 2 choices are borla hush and greddy evo2.
or go for the catless invidia up-pipe first and get the exhaust in a couple of weeks.
any input for a new modder?
ibyu4dola is offline
post #2 of 15 Old 05-01-2008, 06:47 AM
tom_noland's Avatar
tom_noland is an unknown
Send a message via AIM to tom_noland Send a message via Yahoo to tom_noland
go with cheap on a CBE. It's all sound. You might at max get 3-4hp gains.
Tom
'05 WRX Wagon (RIP)
Cobb AP Stg 2
RIP baby....Here I come STi.
Stupid deer.
tom_noland is offline
post #3 of 15 Old 05-01-2008, 07:55 AM
WRXtreme's Avatar
STis come with catless uppipe last time I checked, so really no need to replace. I would either go with a CBE or engine management.
WRXtreme is offline
post #4 of 15 Old 05-01-2008, 10:14 AM
Engine management. It will allow you to flash a stage 2 map and get a little more out of the downpipe. Or just get a tune on the car. Neither of the other parts are really needed, like said the CBE is for sound/looks really.
post #5 of 15 Old 05-02-2008, 02:24 PM Thread Starter
i got a tune from a local guy with a tactrix cable.
so where do i go from here?
post #6 of 15 Old 05-02-2008, 03:51 PM
Jave's Avatar
Jave is more helpful than not
get a protune or starting adding more expensive parts.
▼SbiΣ Mi▼
Jave is offline
post #7 of 15 Old 05-02-2008, 04:41 PM
SuBeast's Avatar
SuBeast is on thin ice
I think either saving up and getting beter EngineManagement or upgrading turbo, injectors, intercooler... The STi is fairly potent in the power department already, with a DP and engine management, you should be very satisfied with just that and then move on to suspension work (if you like handling) or just save up and upgrade the turbo...
FAST
RELIABLE
CHEAP
Pick 2
2006 STi
1990 Toyota Hilux - daily
SuBeast is offline
post #8 of 15 Old 05-03-2008, 10:49 AM Thread Starter
so just having a downpipe on would support a new turbo?
Forced Performance: GT3582HTA Ball Bearing Turbocharger
post #9 of 15 Old 05-03-2008, 11:05 AM
Well that, inectors, fuel pump and a larger intercooler of sorts. The DP sorts out the exhaust portion of that equation though.
post #10 of 15 Old 05-03-2008, 02:48 PM Thread Starter
so step by step would be:
1. injectors
2. fuel pump
3. intercooler
4. turbo
would the sti tmic be sufficient if i upgrade the turbo before i upgrade the ic.
post #11 of 15 Old 05-04-2008, 06:13 AM
Thats pretty much the right steps, a tune has to immediately follow with most those mods both for safety and to get the most out of them. Im really sure that the STI I/C would really limit you especially if the turbo in your previous post is what you are looking at.
post #12 of 15 Old 05-04-2008, 02:28 PM Thread Starter
i dunno.. i might just go with a fp red or green.
or any suggestions on turbos?
post #13 of 15 Old 05-04-2008, 02:49 PM
I like streetable. The Green gives a ton of power but still spools decently. There are certainly larger turbos out there though. The green is going to limit horribly on your STi TMIC. You should look into a much larger intercooler. FMICs are often used as they permit more space but if you're particularly concerned about spool, a green works with a big TMIC as well (although I'd go APS/perrin despite the price because you need size).
Your bypass valve is good for about 20PSI as well so you prob want to replace it when you replace intercoolers. Might I suggest the perrin 100% recirc valve?
Another mod often added is a better boost control solenoid (a 3-port) to help regulate the higher boost levels more smoothly.
And ALL of this needs a tune ASAP once it's on your car.
post #14 of 15 Old 05-05-2008, 03:49 AM
Thats great advice right there. Im with Mosc about streetability. The green should be good for you. Do you have a goal, power wise for the car? Figure that out and then go from there, might be a little easier to pick and choose parts then.
post #15 of 15 Old 05-05-2008, 03:57 PM Thread Starter
probably just into 400
425?
i'd like to be fast but still able to daily drive.
front mount most def.
