i have boost creep.... - Page 2 - Subaru WRX Forum
post #16 of 29 Old 01-04-2009, 10:35 PM
so even with a catted dp with a divorced waste gate wont help in minimizing boost creep?
srninjastar is offline
post #17 of 29 Old 01-05-2009, 02:44 AM
I had the boost spike a while back catted bellmouth DP with EM. It happens sometimes. Just dont "let" it happen too much.
post #18 of 29 Old 01-05-2009, 09:28 AM
It should.
dumdum is offline
post #19 of 29 Old 01-05-2009, 02:36 PM
well i live in Houston and it never really gets that cold down here so boost creep wouldnt happen as often say if i lived up north cause of the colder climate right?
post #20 of 29 Old 01-05-2009, 04:19 PM
Everything you need to know about boost creep - NASIOC
No offense,but your just asking questions that have pretty much been answered in this thread already........
dumdum is offline
post #21 of 29 Old 01-05-2009, 09:48 PM
i apologize for being a dummy and not reading
post #22 of 29 Old 04-08-2009, 07:58 PM
WazzuWRX's Avatar
So I'm throwing the same code (PO244), after I get on it real hard. CEL says its Wastegate Solenoid A. I just had a catless downpipe put on, and flashed it to stage two. From what I've read I need to manually open the wastegate a lil... but how the hell do I do that?
WazzuWRX is offline
post #23 of 29 Old 04-09-2009, 10:37 PM
jed344's Avatar
when it was 32deg and below i had boost creap it is now 50deg and have none. I have catless tbe by the way so weather does effect it alot
jed344 is offline
post #24 of 29 Old 04-10-2009, 03:41 PM
you aren't protuned correct? if you aren't then the sri is your culprit. i have a full catless turboback (custom made) and i'm running the stage 2 accessport mapi had the aps sri installed and it maintains the stock diameter where the MAF is. i was boost spiking 20.6 psi and threw the wastegate high/over performance code or something like that.. and the flashing cruise light means there is an issue w/ the fuel pump if i remember correctly. i would fuel cut when i hit that much boost and it scared the hell out of me the first time. i talked to my buddy who knows his shit, it was actually his exhaust i installed.. anyways, put your stock airbox back on, reset your ecu, reflash, you should be good. be sure to post results.
habitatxskat is offline
post #25 of 29 Old 04-10-2009, 03:48 PM
Jebus..........you have no idea what in god's green earth you are even talking about.An air intake has nothing to do with boost creep and a flashing cruise light just means you have a CEL in the 32 bit ECU's.Gotta love newbies.........
dumdum is offline
post #26 of 29 Old 04-10-2009, 03:55 PM
i'm telling you my experience with the short ram, i put the stock back on and i'm not having issues. so it magically vanished?
oh and that is not true about the flashing cruise light because i was throwing a code before that and i didn't get a flashing cruise light.
post #27 of 29 Old 04-11-2009, 09:02 AM
It flashes to bring your attention to the CEL.Mostly missfires or a knock event.
This thread is about "boost creep" not "boost spike".That is why I said you have no idea what your talking about because you can't even follow the context of the thread.All your going to do is confuse people into thinking that by going back to stock intake it will cure their boost creep issue when it won't.
dumdum is offline
post #28 of 29 Old 04-11-2009, 09:52 PM
Hunt around for adjustments for your particular turbo, the TD04-13T, commonly just referred to as the TD04.
The shop manual for the car will have some adjustment guidelines, as each one is set just a little differently from the factory to account for differences in the TD actuator's springs.
I popped a search for you on NASIOC and it turned up this for your reading pleasure.
Search string was "td04 wastegate adjustment" without the quotes and it turned up a large number of threads.
Exarch is offline
post #29 of 29 Old 04-12-2009, 11:33 AM
WazzuWRX's Avatar
Thanks Exarch. I think I need to loosen it about 1 1/2 turns then I wont see the boost creep. Hopefully this works. I'll post my results.
WazzuWRX is offline
