Old 01-05-2008, 12:10 PM   #1 (permalink)
bxwrx3's Avatar
Reputation: bxwrx3 is an unknown
i have boost creep....
im still wondering why i have boost creep when i flashed XPT stage 2. mods are invida V2 downpipe megan racing catback and SPT SRI. Heres a video of what happens when im hitting it. its not actually me and the only difference is my cruise light starts flashing with the CEL.
Old 01-26-2008, 04:58 AM   #2 (permalink)
Reputation: zerokelvin is an unknown
Just wandering how cold is outside when you were doing this?
Mine started doing this all the sudden but it was like 35 degree's out.
Old 01-26-2008, 08:52 AM   #3 (permalink)
If you are running a catless TBE then that maybe part of the problem.Enginemanagement cannot fix boost creep.It is a design/mechanical issue that require a physical change to the turbo wastegate.Pretty well known issue on the VF39 STi's and any 2.5L WRX with a TD04L-13T.
Aarg matey!
ECU Pirated by RomRaider
Old 01-26-2008, 09:45 AM   #4 (permalink)
JBWRX06's Avatar
Reputation: JBWRX06 is an unknown
i am stage 2 catless, running 17psi and have not thrown a code
Old 01-26-2008, 12:25 PM   #5 (permalink)
Longshot's Avatar
Car: 05 WRX
Ron what if he altered the map (fuel, timing, boost) from the OTS setup. Could that help him run smoother and get rid of the creep/spike?
DTRacing Tuned
Old 01-26-2008, 05:01 PM   #6 (permalink)
Creep and spike are two different things.Spike is a momentary rise above preset boost levels durring first onset of w.o.t. Creep happens at high rpms after boost onset and is incontrolable.You could have 0% solenoid dutycycle (wastegate pressure/7-10psi) and be seeing 15+psi at redline.The video shown is worhtless as it shows nothing relevent to boost preesure.A datalog would have been 20x more helpfull.
Everything you need to know about boost creep - Factory 2.5L Turbo Powertrain - NASIOC
Boost Spike vs. Boost Creep - DSM Forums
How To Cure Boost Creep By Porting - DSM Forums
boost creep cobb - Google Search
Aarg matey!
Old 01-26-2008, 09:53 PM   #7 (permalink)
kh15's Avatar
Reputation: kh15 is an unknown
is there a chance of boost creep with a catted dp and a protune on the 2.5 liters?
Old 01-27-2008, 08:51 AM   #8 (permalink)
What E.M.?
Aarg matey!
Old 01-27-2008, 08:53 AM   #9 (permalink)
Yes but not as much.The colder it is,the better chance of it happening.Durring summer it wouldn,t really be a problem.
Aarg matey!
Old 03-12-2008, 07:35 AM   #10 (permalink)
pddvl1's Avatar
Reputation: pddvl1 is an unknown
I replaced my stock wastegate solenoid with the gm style from a typhoon and my spike whet away , you have to retune the boost map in the computer with open source and it works fine no more spike on my internal wastegate and no creep
Old 03-12-2008, 10:13 AM   #11 (permalink)
IH8PVMNT's Avatar
Reputation: IH8PVMNT is an unknown
IM NOT PROTUNED YET HAVE cobb tbe and cobb ap stage 2 and 5th gear at WOT i throw a cel for overboot and wastgate performance..
Old 03-12-2008, 10:42 AM   #12 (permalink)
Longshot's Avatar
Car: 05 WRX
A 3port solenoid before your tune might help too man, not to mention give a bit more room to tune up the boost safely.
DTRacing Tuned
Old 03-27-2008, 02:05 PM   #13 (permalink)
Reputation: hollingst is an unknown
Did you have a vent to atm bof installed? The stock location of the MAF can cause some serious issues here. I had a similar problem and when the code was read it was for rich fuel. Retuning with relocating of the MAF solved this issue.
Old 03-27-2008, 02:56 PM   #14 (permalink)
CODE! he said CODE! I swear I heard: "I threw a ####ing TOAD!!!!"
Engineers can't spell, sorry!
Old 03-27-2008, 05:18 PM   #15 (permalink)
Have you had the CEL read to see what it is ?
