FMIC or TMIC - Subaru WRX Forum
post #1 of 16 Old 07-12-2007, 03:13 PM Thread Starter
Skramps is an unknown
FMIC or TMIC
so I'm saving up for a new turbo and intercooler, If I where to go with the APS SR40 turbo could I get away with using the APS topmount or would I have to go with a front mount. my goal is a 400hp daily driver, the turbo can do it and if a there is a topmount out there that can too I'd like to go with it
Skramps is offline
post #2 of 16 Old 07-12-2007, 03:19 PM
ArmyWRX's Avatar
ArmyWRX is more helpful than not
Send a message via AIM to ArmyWRX Send a message via Yahoo to ArmyWRX
being that your in alabama I WOULD go with front mount.... the reason is because of the heat there.... there are TMIC(Top mount intercoolers) that can handle 500hp.... im sticking with a tmic untill i get back to the lower 48 but thats only because im stationed in alaska....
ArmyWRX is offline
post #3 of 16 Old 07-12-2007, 06:41 PM
I pushed over 400 whp on a TMIC, however with the flow rate of the SR40 you might be limiting yourself in the TQ area.. I was only able to pull 361 ft lbs of TQ out of my setup with the restrictive TMIC.. By "Restrictive" I am referring to a Perrin TMIC. with a GT35R. But you could probably get away with a TMIC, try to find a used cheap one to try out..
SR40 flows 595 @ 14.7 psi
GT35R Flows 880 @ 22 psi.
post #4 of 16 Old 07-12-2007, 07:11 PM
TMIC unless you want more lag and bling. That turbo doesn't flow enough to require a FMIC
post #5 of 16 Old 07-13-2007, 12:50 AM Thread Starter
so are you saying the GT35R would be a better choice for a Topmount setup
Skramps is offline
post #6 of 16 Old 07-13-2007, 02:41 AM
No I'm sure he's saying the opposite. A GT35R is way too big for a tmic...
WReXd is offline
post #7 of 16 Old 07-15-2007, 12:28 AM
Jamo06TR's Avatar
Jamo06TR is an unknown
Send a message via AIM to Jamo06TR
Never buy two of the same mods. If you want big power even eventually, go with the FMIC off the bat, doesnt matter what turbo you have as long as your tuned for it, and once you have your FMIC set up, your good to go and you dont have to worry about selling your aftermarket TMIC that everyone told you to buy.
jamopwnsu
Jamo06TR is offline
post #8 of 16 Old 07-15-2007, 02:17 AM
+1 with jamo. im sure u could get away with an upgraded topmount, but ## numbers will be bigger with a fmic. i agree with not buying 2 of the same mods. i wanted to replace alot of parts out of my 03, and don't want to spend the money again for the same mods, so im going with an sti. lol, that and i have enough saved for one. lol.
post #9 of 16 Old 07-15-2007, 02:24 AM
im sure the giant APS TMIC would support it but you will probably make more torque with a fmic just like everyone else said.
Robby
02 rex is gone.
I defected to an evo :)
Evo is gone :(
Now I got nothing.
WRXKidid775 is offline
post #10 of 16 Old 07-15-2007, 04:14 AM
Well, it really depends on what you want to get out of your car in the end. Personally i don't want to deal with the attention, safety issues and lag of a fmic, so I decided to go with a tmic and meth. I know this setup will support everything I'm planning to throw at it in the future, so I'm not worried about having to upgrade. The reason I bring this up is because the number you mentioned (400 hp) is attainable with a tmic, especially if you are willing to consider meth injection. Purchasing a tmic doesn't necessarily mean you're not planning for the future.
WReXd is offline
post #11 of 16 Old 07-16-2007, 10:17 PM
Perrin Top Mount Inter-cooler, Conservative Tune in Feeble attempt to save then "STOCK" 2002 Transmission...
Edit: No Meth..
post #12 of 16 Old 07-16-2007, 10:29 PM
ArmyWRX's Avatar
shoaf you got to think about where he lives and how hot it gets.... go with the front mount.... tmic would do fine but in the summer you would suffer BAD heat soak....
If you make me look impress me....
ArmyWRX is offline
post #13 of 16 Old 07-16-2007, 10:51 PM
Edit: No Meth..
WOW, that's impressive!
WReXd is offline
post #14 of 16 Old 07-18-2007, 05:26 PM
I don't live in AL and don't know the climate there.. Elevation has a more dramatic effect the "Heat Soak".. Besides, I am not pushing towards a TMIC, only stating that it is possible.. Acutally if you read my posts I openly admit and display via my graph that a TMIC limits TQ horribly on larger turbos...
Thanks for the props, I can't wait to get the block fixed up so I can retune with my FMIC, meth, and other goodies in hopes of reaching 600whp..
post #15 of 16 Old 07-18-2007, 06:58 PM
sweet baby jesus!
i want details.
Robby
02 rex is gone.
Evo is gone :(
Now I got nothing.
