FMIC spray - Subaru WRX Forum
post #1 of 2 Old 08-28-2011, 03:41 PM Thread Starter
wrx1456's Avatar
wrx1456 is more helpful than not
FMIC spray
Yeah, I know a few of yall said that its not needed, but it only took a couple dollars and an hour to add it, so why not? All of the hoses and everything was left in place after the FMIC was installed; so I re-routed the hose to the front, added two windshield washer spray nozzels and a tee. The nozzels put out the same amount of water, but dont have the wide spray pattern of the IC spray nozzels. After playing with them, I have pretty good coverage now. Made some aluminum brackets so I dont have to worry about rust. Best of all, you cant see them. ( all the dead bugs are from one trip yesterday. We have lots of bugs down here ). Now I need to get a pressure switch to trigger it autumatically.
06 STI
http://www.armslist.com/?utm_source=c000017&utm_medium=plink&utm_campaign=p017903
wrx1456 is offline
post #2 of 2 Old 08-28-2011, 04:57 PM
Well at least you did a good job hiding everything. With any luck maybe you'll see some results from it...
