Ebay TMIC - Page 2 - Subaru WRX Forum
post #16 of 21 Old 08-04-2010, 10:28 PM
Mine was big enough, but I did end up getting the ZeroSports Splitter anyways. It wasn't a big difference over the STI splitter.
post #17 of 21 Old 08-05-2010, 11:40 AM
I'm currently running a stock 06/07 STi splitter in my 07 WRX scoop with a stock 07 WRX tmic... the main difference I notice is that there is a larger collection of bent fins and bug guts/other debris on the bottom half instead of the middle and top half of the intercooler. I'm also using the stock 06/07 STi bellows and I'm pretty sure it makes contact with my stock 07 WRX tmic the same way the WRX bellows did without the splitter. This is all in preparation for a larger aftermarket tmic some day... just figured I'd get it out of the way now
post #18 of 21 Old 02-13-2011, 08:31 PM
AllExtinct's Avatar
I was a lil bit worried about the Ebay TMIC so I was thinking picking up one of the used STI coolers. My questions are will it bolt on good to a WRX and will I be able to use Perrin IC hoses with it?
I have a Cusco tower bar in the front to and there doesnt seem to be any extra space for something bigger to fit.
AllExtinct is offline
post #19 of 21 Old 04-13-2011, 12:19 PM
rex2002's Avatar
i know a lot of the members out here state that some of the knock off tmic on ebay get a lot of "heat soak" has anyone every thought about putting some type of heat shield fabric on the underside of any tmic to help with this issue.i found this site - Panels . it sells many different types that could mount on the underside and be folded over on the edges. has anyone thought of that/currently using this set up? any "2cents" on this. would it be a good idea or not?
rex2002 is offline
post #20 of 21 Old 04-13-2011, 12:32 PM
blk05WRX's Avatar
I'm guessing that would probably reduce the amount of flow through the intercooler. A better idea would be to wrap the downpipe and put a heat blanket on the turbo. For the cost of that, you could probably a get a better intercooler with better fin density.
2005 WRX Cobb Stage 2
2009 Outback
blk05WRX is offline
post #21 of 21 Old 04-13-2011, 06:42 PM
Its a bad idea. Cheap intercoolers have heat soak because they are made of cheap and thin metal. A higher quality intercooler normally has a better fin density, less boost drop, and in general just cools the charge a lot better because of better flow.
