Drop in air filters - Subaru WRX Forum
post #1 of 14 Old 06-14-2007, 02:20 AM Thread Starter
Wilks132's Avatar
Wilks132 is an unknown
Drop in air filters
Ok, so i scratched the intake idea for now..... Im going to instead install a silencer delete from fastwrx.com and put a new drop in filter in. Which is the best to go with? I have found the Perrin foam filters, a K&N filter and an STI filter. The STI being the most expensive. Anyone used any of these filters ot are they pretty much all the same? I also found an induction cover made by Blitz that replaces only the top half of the air box, kind of the best of both worlds. However, I dont know if you can use other filter brands with it or if it even worth installing.
Wilks132 is offline
post #2 of 14 Old 06-14-2007, 09:46 AM
I have a k&n, they are all very close in the amount of proformance they provide.
nagyhead is offline
post #3 of 14 Old 06-15-2007, 08:45 PM
I have a k&n in mine too, just make sure you get those tiny plastic nibs back in the slots before you secure the metal clips... for some reason, mine was a little hard to get in there, but if you encourage it with a screwdriver or something, the cover will pop right back on.
post #4 of 14 Old 06-15-2007, 09:51 PM
Erlend is an unknown
I just shaved a tiny bit off the moulding of the K&N and it slid right in. You could do either I guess. I just never liked forcing something to go where it doesn't want too. If you look at the stock filter and the K&N the sealing lip is way thick on the K&N. I just shaved it down a tad right where the clips are. Still seals awesome and requires no forcing on the airbox.
Erlend is offline
post #5 of 14 Old 06-15-2007, 11:48 PM
fitwagun is an unknown
sti part are mostly for the name. the decals are like 40.00! k&n all the way.
fitwagun is offline
post #6 of 14 Old 06-16-2007, 12:43 AM
king723 is an unknown
I have a k&n with the silencer delete..I was using the perrin filter for awhile but switched to the k&n and noticed more power. Not that its important but the bov is a little louder too..
king723 is offline
post #7 of 14 Old 06-16-2007, 12:45 AM
haha yeah thats always a pain in the ass and it sounds like shit if you forget to secure it properly..the worst are on the 2.5 n/a on outbacks those are a bitch to get sometimes.
king723 is offline
post #8 of 14 Old 06-16-2007, 04:14 AM
ArmyWRX's Avatar
ArmyWRX is more helpful than not
Send a message via AIM to ArmyWRX Send a message via Yahoo to ArmyWRX
if you really want to hear the turbo and bov get a cai.... and catless dp.... and for those who say that they will make your car run lean it doesnt i have mine for over 5000 miles.... i had my car out at the drag strip on wensday and was in the low 9s high 8s(1/8th mile) but it was cool drivin around with a 8.8 dial in time on my car!!!! got a lot of looks....
ArmyWRX is offline
post #9 of 14 Old 06-16-2007, 08:09 AM
You mean the thousand of proffesional tuners that have logged the problem first hand?Are you just assuming your not running lean because you don't have a CEL or because you have actually logged the car using a wideband?You might want to do alittle more research on why the intakes do cause problems.It is far from just speculation..... CAI are the worst cause of any intake problems because of the turbulence they create.At high airflow and openloop mapping is where the lean condition generally arises.Not every intake causes problems but CAI cause 90% of them.
http://www.cobbtuning.com/info/?ID=3223
http://www.ecutek.com/tuning/induction/
dumdum is offline
post #10 of 14 Old 06-16-2007, 06:07 PM Thread Starter
Wilks132's Avatar
Thanks for the replies.. I am going to drop in a K&N and use the GP Moto silencer delete and get the SPT CBE. I might get the SPT intake only becasue its a short ram and not a CAI becasue everyone says they are bad. I will however, put the car on a dyno before and after every mod. I will post the results. I live in Wilmington, DE anyone know of an AWD dyno in the area??
Wilks132 is offline
post #11 of 14 Old 06-18-2007, 11:40 PM
cold air or short ram it doesnt solve the turbulance problem.. spt claims to have found the right location for the o2 sensor but im guna wait...
fitwagun is offline
post #12 of 14 Old 06-19-2007, 12:20 AM
http://www.stealth316.com/2-awddynos.htm i always post this for everyone looking for a dyno, see if it helps.
post #13 of 14 Old 07-01-2007, 08:03 AM
bxwrx3's Avatar
bxwrx3 is an unknown
with an upgraded panel filter can you hear the turbo spool up like you would with an intake?
bxwrx3 is offline
post #14 of 14 Old 07-01-2007, 03:44 PM
ArmyWRX's Avatar
nope im sayin a few say that
ArmyWRX is offline
