doughnut flange/gasket - Subaru WRX Forum
post #1 of 11 Old 06-04-2009, 03:40 AM Thread Starter
anyone know where i can find one? autozone or napa maybe?
just put a 4" DP on my beast and its not bolting up correctly to the borla i have on. the DP is a flat flange while my CB is designed to fit the stock DP doughnut flang/gasket. gona get a used cobb V2 tuner soon by the way...
if anyone knows where i can get that gasket for cheap let me know
thanks
srninjastar is offline
post #2 of 11 Old 06-04-2009, 01:45 PM
you need to take it to an exhaust shop and get the doughnut flange cut off and have him weld a flat flange in its place. Or else you will have a leak. And then you could get a flat gasket.
post #3 of 11 Old 06-04-2009, 03:01 PM
ratfink's Avatar
ratfink is a helpful contributing member
I run a doughnut without leaks in this situation
Brad
ratfink is offline
post #4 of 11 Old 06-04-2009, 10:38 PM
Either do what baller said, or there is a couple different adaptors that can be bought for such a situation.
post #5 of 11 Old 06-05-2009, 01:18 AM
oh yea i forgot, here is the link......
keep in mind this for a 3in flat style flange DP to 2.5 donut flange.
RallySportDirect.com - Elite AWD 3" Down Pipe to Stock/Tapered Cat back Adapter
post #6 of 11 Old 06-05-2009, 03:19 AM Thread Starter
im just gona go to a muffler shop on saturday, have them cut the doughnut flange on the cat back and weld a flat flange to it then bolt it up and be done
post #7 of 11 Old 06-05-2009, 06:47 AM
You have a 4" DP ??? Didn't think they made them for your year yet ?
post #8 of 11 Old 06-05-2009, 10:45 AM
I think he's exaggerating slightly. The top part of his downpipe is probably about the same size as the opening behind the turbo - which is about a 4" oval-shaped opening (measurement taken on the larger horizontal part of the oval) and it's probably a bellmouth downpipe. I'm sure the actual pipe itself tapers down to 3" (give or take) by the time it hits the flange where it connects to the cat back.
He might also suffer from what is known as "small downpipe syndrome." Although this subconscious or conscious envy may solely be based on the idea that a larger downpipe is universally more satisfying and appealing to a sexual partner, other implications arise from the fact that a large downpipe has been seen in many cultures as a symbol of high masculinity, dominance, and power. Tee hee.
post #9 of 11 Old 06-05-2009, 02:36 PM Thread Starter
LOL...that was pretty hirrarious. but the reason why i got the 4"(which tapers to a 3"exit) is because the guy i got it from slammed his car to the ground and since the dp was to big it scraped the ground. so he had it for a year just chilln in his garage and i had asked around and i got his number. long story short i got it from him for $100 which was a steal.
as for the dp not mating up to the cb, it connects no problem but since the dp is flat and the cb is flared out to fit a doughnut flange its not matting correctly and causes a rather annoying leak. so thats why im just gona go get that flared out piece cut off and get a flat flange welded to it so that way i wont have an exhaust leak.
ps....my friends and i got a kick by putting the down pipe "on that area" and just walking around. we dubbed it the "donkey dong"
post #10 of 11 Old 06-08-2009, 08:46 AM
^^^ Funny stuff right there..... That's MY nickname....
post #11 of 11 Old 06-08-2009, 07:41 PM Thread Starter
hahahaha
