Old 08-17-2008, 11:15 AM   #1 (permalink)
Reputation: clipsy is an unknown
cobb ap
hey i was trying to set up LC on my car and i was wondering cause i tried to do it, and it said i need the test mode connecters pluged in when i try to reflash the ecu
Old 08-18-2008, 12:07 AM   #2 (permalink)
Reputation: Chase is more helpful than not
There are 2 green connectors under the dash in line with the steering wheel. Connect them. You have a small connector that came with your AP that is either 1 wire loop or 2. That connects to a connector right near the green ones. This should all be in the manual. Mine is an 02... yours may be a little different.
Old 08-18-2008, 12:52 AM   #3 (permalink)
Reputation: BLACK07STI is an unknown
Once You Pluged In The Connectors On The Ap Go To Change Map Then Reflash And Choose The Map You Want, Once You Have Down Loaded The Lc Off The Cobb Web Page. Because The Lc Does Not Come On Ap.
