catless uppie - Subaru WRX Forum
post #1 of 12 Old 06-25-2007, 01:49 PM Thread Starter
0fourSTI's Avatar
0fourSTI is an unknown
catless uppie
does anyone know if the 04 sti has a catless uppie or not? also i wanna do a downpipe and all that good stuff what can i reuse from the stock exhaust because ive heard people say that there is no real power gains from exhaust its mostly just sound so what can i do with my stock exhaust? just get a down pipe and uppie?
0fourSTI is offline
post #2 of 12 Old 06-25-2007, 03:22 PM
ArmyWRX's Avatar
ArmyWRX is more helpful than not
Send a message via AIM to ArmyWRX Send a message via Yahoo to ArmyWRX
really there are people that say a cbe wont give you any power.... i saw power gains on a dyno from a cbe and cai.... i dont have the dyno sheet here to prove it its with my car.... i would recommend any one to go get a tbe....
ArmyWRX is offline
post #3 of 12 Old 06-25-2007, 03:39 PM Thread Starter
0fourSTI's Avatar
well i guess my question is can i due a turbo back exhaust and still use my stock sti muffler and still see the horse power gains
0fourSTI is offline
post #4 of 12 Old 06-25-2007, 04:00 PM
doctorjf21's Avatar
doctorjf21 is an unknown
Yes you have a cat in the uppipe and yes you can get a DP and use the stock CBE. You might need a flange though with a bigger DP. You will see a noticeable difference in HP with a catless dp only but i would also recommend a catless uppipe for safety purposes and a little quicker spool.
doctorjf21 is offline
post #5 of 12 Old 06-25-2007, 04:58 PM
wrx3r's Avatar
wrx3r is more helpful than not
with the amount of boost you can run with a sti using its stock vf39 you will want a catless up pipe as well as down pipe. a cat back will net small hp gains but if your on a small budget you can use the stock sti catback.
bigger and better than ever
wrx3r is offline
post #6 of 12 Old 06-25-2007, 08:32 PM
isd_intrepid's Avatar
isd_intrepid is an unknown
Send a message via Yahoo to isd_intrepid
Will installing a catless uppipe cause the CEL to go off?
isd_intrepid is offline
post #7 of 12 Old 06-25-2007, 08:47 PM
wrx3r's Avatar
i never had a cel come on when i installed mine, but maybe my tuner cleared it before it could come on.
wrx3r is offline
post #8 of 12 Old 06-26-2007, 07:54 AM Thread Starter
0fourSTI's Avatar
does anyone think its bad if i just remove the resonator from my air intake with out replacing it with an elbow from fastwrx.com or sumthing like that. it will suck air from the fenderwell instead of the ram air.
0fourSTI is offline
post #9 of 12 Old 06-26-2007, 08:54 AM
WRXtreme's Avatar
Stock STi uppipes are catless from the factory. The real power in the exhaust comes from either completely removing both cats or replacing them with a single high-flow cat. You will be able to hook your STi catback with most aftermarket downpipes, to make sure just check with the manufacturer. I personally would not remove the resonator from the airbox without replacing it with an elbow, but thats just me.
WRXtreme is offline
post #10 of 12 Old 06-26-2007, 03:34 PM Thread Starter
0fourSTI's Avatar
i have a question on hooking up my air fuel gauge. im assuming i hook it up to the front o2 sensor which is the air fuel. but in the directions it says it hooks up to the signal wire? does anyone no what color the signal wire is on the front o2 sensor or is there a better way to hook up that air fuel meter
0fourSTI is offline
post #11 of 12 Old 06-26-2007, 05:51 PM
phillyman is an unknown
i thought the best place was on the DP about 9 inches from turbo, i could be wrong though
phillyman is offline
post #12 of 12 Old 06-26-2007, 06:40 PM
WRXtreme's Avatar
I've read over and over to stay away from the front o2 sensor. Although it is a semi-wide band o2 sensor and if you try to tap into it the ecu might not get proper readings from the o2 sensor and the car will not run right. The rear o2 sensor is a narrow band o2 sensor and is pretty much just for emissions. If you want an gauge that is going to work properly get a wide-band o2 sensor and hook the guage up to that.
WRXtreme is offline
