i have a few minor mods to my 07 wrx wagon w atune from DSG of Norwood. If i turn my a/c on at a low idle the car is looking to stall and is a pain to drive. Also i have a FMIC and the car seems to be running hot with a bit of turbo lag. My CAI does not have a heat shield or box around it. Could this be the reason? If i extend the piping into my fender would this help the issue?
It might give you more problems. You don't want to do that, it can really throw off MAF readings. The lag is probably because of the front mount, unless you have an upgraded turbo as well, most front mounts are for handling bigger turbochargers. So you probably would get some lag using a stock turbo. This is just a guess, I don't know anything about the flow rating on your particular FMIC and there are smaller ones that would be more accommodating to a stock turbo.
What did you get it tuned with? Because if it's a AP. You can easily turn on the Idle adjustment settings on when the A/C is on. I didn't know that feature existed until I took my car back to my tuner after my recent tune. Because my car was stalling and getting really bad jumping revs with the A/C on. In short, with the A/C off the idle stays the same. Once the A/C is on, the ECU will adjust the idle to keep it from bouncing around and dropping to low.
