Boost gauge vaccum hose - Subaru WRX Forum
post #1 of 7 Old 08-20-2007, 07:57 PM Thread Starter
Scooby2006's Avatar
Scooby2006 is an unknown
What hose is the best hose to tap into for a vaccum/ boost gauge. pics would also help i have an sti i dont know if it would be differenty from a wrx i dont think so though...????
Scooby2006 is offline
post #2 of 7 Old 08-20-2007, 08:21 PM
wrxgtr's Avatar
wrxgtr is more helpful than not
Send a message via Yahoo to wrxgtr
i tee'd the vacuum hose that goes to the bov for mine
MIKE
TUNED BY 555 MOTORSPORTS
visit me @ www.myspace.com/subienews
wrxgtr is offline
post #3 of 7 Old 08-21-2007, 05:13 PM
SWFL Scooby's Avatar
SWFL Scooby is an unknown
I found success tapping the vacuum line from the fuel pressure regulator
D-Rock
Under constant pressure
SWFL Scooby is offline
post #4 of 7 Old 08-21-2007, 05:19 PM
I wouldn't suggest tapping in on any part of the fuel delivery system.. A leak there could cause a malfunction of the regulator readings causing major damage.. Most people "T" into the line leading to the Bypass Valve or Blow off valve (which ever you have)..
post #5 of 7 Old 08-21-2007, 05:41 PM Thread Starter
Scooby2006's Avatar
see my problem is i did T it into the factory bov line and its only reading 4psi on the gauge with no vaccum leaks could this be possible. I might only be running 4psi.
What size vaccum line should i use comming from the bov to the gauge
post #6 of 7 Old 08-22-2007, 04:19 PM
Did you use the line that came with your Gauge? Is that 4psi at WOT?? Does the car feel strong?
post #7 of 7 Old 08-23-2007, 03:19 AM
mystilexzero is an unknown
agreed a little more detail could help us find out the anwser and like shoaf said the blow off valve vacuum line is an ideal place for alot of boosted cars to run a boost gauge.
mystilexzero is offline
