sounds like you want to control boost. You don't need an upgraded wastegate to do that. Also, an upgraded wastegate won't really help you do that. You need EM
You could do an external wastegate, but this is going to involve some custom fabrication. I haven't seen anything "bolt-on" for the WRX yet. You can also control when the wastegate opens, which will have an effect on the amount of boost that you get.
Wastegates can/do control boost somewhat, but they really aren't used to adjust the amount that you get. If you want the ability to do that, do as stated above and get some engine management.
If your going to be doing a TBE and your worried about the dreadful 2.5l boost creep, all you need to do is get some EM and port your stock wastegate and you won't have to worry about it
-Brad
05 wrx sti
▼SùbiΣ Mäƒiä▼
Thankx a ton how much do you think that will end up costing?
That all depends on the brands and how far you want to go. The port job is very simple and shouldn't cost you much, you could do it yourself but if you don't know what you doing your better off letting a professional handle it.
-Brad
05 wrx sti
▼SùbiΣ Mäƒiä▼
Could you tell me how I would go about porting it? because I have alot of friends that know what their doing.. and could help me..
That's an area I wouldn't want to attempt on my own. If it was me I would remove the turbo and send it somewhere like Deadbolt or Slowboy and have them port it for me, I could probably do it myself but I don't like taking that risk, especially with the turbo. Another way you can help fix the creep issue is by putting a catted dp on with the EM, that has been know to work also.
-Brad
05 wrx sti
▼SùbiΣ Mäƒiä▼
