12-02-2007, 01:45 PM
#1 (permalink )
Is a 44mm EWG louder than a 38mm?
like the title says, just wondering as i am in the market and am not sure which one i want to get
12-02-2007, 03:43 PM
#2 (permalink )
44 will be louder because it is bigger and allow better boost control.
Robby
02 rex is gone.
I defected to an evo :)
12-02-2007, 06:12 PM
#3 (permalink )
Club Region : Southeast
Do you have an aftermarket turbo?? If not, why would you externally gate it?
D-Rock
Under constant pressure
12-03-2007, 05:40 PM
#4 (permalink )
Club Region : Midwest
Better boost control, granted you will not see as much gains with the stock turbo as you would with a bigger one.
12-03-2007, 06:13 PM
#5 (permalink )
Personally, I just think the $$ could be better spent, but to each his own
D-Rock
12-05-2007, 11:44 AM
#6 (permalink )
The 38 has a higher pitched sound (same exhaust exiting a smaller diameter opening). It's harsher sounding in my opinion. I have a 44mm on my 20g and I would never go back to an internal wastegate.
12-05-2007, 11:46 AM
#7 (permalink )
Also, the 38mm is more likely to leak because it is a gasket flange vs the v band flange of the 44mm.
Linear Mode
