-   -   Is a 44mm EWG louder than a 38mm? (http://www.wrxtuners.com/forums/f75/44mm-ewg-louder-than-38mm-21322/)
TexRex22 12-02-2007 01:45 PM
like the title says, just wondering as i am in the market and am not sure which one i want to get
WRXKidid775 12-02-2007 03:43 PM
44 will be louder because it is bigger and allow better boost control.
SWFL Scooby 12-02-2007 06:12 PM
Do you have an aftermarket turbo?? If not, why would you externally gate it?
wrxman420 12-03-2007 05:40 PM
Better boost control, granted you will not see as much gains with the stock turbo as you would with a bigger one.
SWFL Scooby 12-03-2007 06:13 PM
Personally, I just think the $$ could be better spent, but to each his own
06rexwagon 12-05-2007 11:44 AM
The 38 has a higher pitched sound (same exhaust exiting a smaller diameter opening). It's harsher sounding in my opinion. I have a 44mm on my 20g and I would never go back to an internal wastegate.
06rexwagon 12-05-2007 11:46 AM
Also, the 38mm is more likely to leak because it is a gasket flange vs the v band flange of the 44mm.
