Old 12-02-2007, 01:45 PM   #1 (permalink)
Reputation: TexRex22 is an unknown
Is a 44mm EWG louder than a 38mm?
like the title says, just wondering as i am in the market and am not sure which one i want to get
Old 12-02-2007, 03:43 PM   #2 (permalink)
Reputation: WRXKidid775 is more helpful than not
44 will be louder because it is bigger and allow better boost control.
Robby
02 rex is gone.
I defected to an evo :)
Old 12-02-2007, 06:12 PM   #3 (permalink)
SWFL Scooby's Avatar
Club Region: Southeast
Reputation: SWFL Scooby is an unknown
Do you have an aftermarket turbo?? If not, why would you externally gate it?
D-Rock
Under constant pressure
Old 12-03-2007, 05:40 PM   #4 (permalink)
wrxman420's Avatar
Reputation: wrxman420 is more helpful than not
Better boost control, granted you will not see as much gains with the stock turbo as you would with a bigger one.
Old 12-03-2007, 06:13 PM   #5 (permalink)
Personally, I just think the $$ could be better spent, but to each his own
D-Rock
Old 12-05-2007, 11:44 AM   #6 (permalink)
Reputation: 06rexwagon is an unknown
The 38 has a higher pitched sound (same exhaust exiting a smaller diameter opening). It's harsher sounding in my opinion. I have a 44mm on my 20g and I would never go back to an internal wastegate.
Old 12-05-2007, 11:46 AM   #7 (permalink)
Also, the 38mm is more likely to leak because it is a gasket flange vs the v band flange of the 44mm.
