240hp with 2006 wrx? - Page 2 - Subaru WRX Forum
post #16 of 25 Old 09-14-2007, 05:41 PM
STi_from_DSM's Avatar
STi_from_DSM is an unknown
A regular subie comes stock with 225 base. With a downpipe/exhaust/K&N I doubt you would come anywhere close to 240 awhp. I figure youd run around 170 awhp stock. If you do go with a different turbo you have to get a new clutch, and if you get a new clutch you need a new tranny (To be on the safe side) Then you might as well go all out and get performance everything. You said youre on a budget, so id say that means dont upgrade it anymore than possible on your budget. You will need a new fuel pump, start with that. Upgrade the small stuff that youll need eventually and then save your money for the big stuff.
STi_from_DSM is offline
post #17 of 25 Old 09-15-2007, 10:40 AM
605wrx's Avatar
605wrx is an unknown
I think the base # on the 06s are higher as far as whp.
the stock clutch will hold up for a while(depending on the type of driving the size of the turbo and driver).
the 06s do have a stronger tranny (in comparison to previous years) and with a street clutch kit it should be fine (again, depending on the type of driving the size of the turbo and driver).
605wrx is offline
post #18 of 25 Old 09-18-2007, 09:52 AM
koolpaul1082 is an unknown
the kid has an 06, the stock whp is more like 190. like i said before he would be hard pressed to reach 240whp w/o upgrading his turbo.
koolpaul1082 is offline
post #19 of 25 Old 09-18-2007, 09:56 AM
VD5505's Avatar
shouldnt he get an up pipe for his car before he gets it dyno
VD5505 is offline
post #20 of 25 Old 09-18-2007, 10:00 AM
RedWingKoz is an unknown
From what I know, he doesn't really need an uppipe with an 06. The 06 uppipe is catless and is fine until you really start looking into much more horespower.
RedWingKoz is offline
post #21 of 25 Old 09-18-2007, 10:04 AM
exactly, the stock one is more than enough for now and the money is better well spent elsewhere!
post #22 of 25 Old 09-18-2007, 12:40 PM
shamrock is an unknown
He doesent need to get a new clutch
achavez---
. Just keep the stock clutch. Stock tranny, stock clutch
_Ryan_
2004 Wrb "BUGEYE"
http://www.misubie.com/
shamrock is offline
post #23 of 25 Old 09-19-2007, 09:06 PM
2006wrxturbo's Avatar
2006wrxturbo is an unknown
i dynoed at 205 whp and 240wtq on a dynojet dyno. don't know if those read high or not. i'm pretty much stock. just a CBE, Y pipe, k&n drop in filter. a pro-tuned stage 2 06/07 should be right around 240whp from what i've seen. check some of the dyno videos on youtube. worried about my tranny going at those power levels. although, i've heard that an OTS cobb VF39 map torque curve is less likely to blow 2nd or 3rd gear. anyone hear of this?
2006wrxturbo is offline
post #24 of 25 Old 09-19-2007, 09:21 PM
the torque doesnt blow up the tranny the driver missusing the torque does.
Robby
02 rex is gone.
I defected to an evo :)
Evo is gone :(
Now I got nothing.
WRXKidid775 is offline
post #25 of 25 Old 09-20-2007, 05:31 PM
605wrx's Avatar
Dynojet dynos are pretty accurate. Your tranny will be fine as long as you don't drive like a jackass, pretty much what WRXKidid775 said. It gets old hearing how "weak" suby tranny's are, they aren't that bad, a lot of the time it's the drivers that suck. Congrats on the tq #s.
605wrx is offline
