240hp with 2006 wrx? - Subaru WRX Forum
post #1 of 25 Old 08-23-2007, 03:26 PM Thread Starter
i was wondering if i could hit 240 hp with a pro dyno tune with just my k&n drop in filter, invidia downpipe, apexi gt spec exhaust and im runnin the xpt map. so im hopin any 2006-2007 wrx owners can help me out. if not what other mods would be recommeded to hit that goal? iam on a little bit of a budget so im not tryin to buy anything too expensive right now. thanks in advance
achavez is offline
post #2 of 25 Old 08-23-2007, 03:37 PM
well, on a high reading dyno and a little bit of luck, yes. On a low reading dyno, no.
post #3 of 25 Old 08-25-2007, 12:12 AM
240 bhp or 240 awhp?
mystilexzero is offline
post #4 of 25 Old 08-25-2007, 04:54 PM Thread Starter
240 awhp of course.... wow i thought i would get a lot more help than this
achavez is offline
post #5 of 25 Old 09-11-2007, 08:00 AM
no you cant,i believe its very hard to reach that power level w/o swapping for any turbo thats larger.to come close you would atleast need a huge intercooler, ypipe tubes,meth-inj,crank pulley,maybe even a intake as long as you can get a good tune.
koolpaul1082 is offline
post #6 of 25 Old 09-11-2007, 08:12 AM
metroscub's Avatar
I do not agree with that at all. that sounds like overkill to me(though granted paul, you are right, that will get you there). 240awhp is not a large number at all IMO, I know for a fact that you could pull 240 awhp with the setup(after a great tune, focus on the word great, I mean it is very possible but it is going to take a talented tuner to make your car those numbers EFFICIENTLY)
I would probably add a walbro fuel pump to the mix(100 bux....www.scoobytuner.com)
FMIC are great, but can be a pain to tune with....
also, take note that the xpt map you are using will not be in use after a pro tune, I mean, the base might still be there, but it will be extremely tweaked and turned upside down.
Matthew
Wow, it can turn well too?
metroscub is offline
post #7 of 25 Old 09-11-2007, 10:41 AM
Deleted due to failed reading comprehension.
Kjott21 is offline
post #8 of 25 Old 09-11-2007, 11:37 AM
metroscub's Avatar
but ken, he has an 06, so he does not need the u/p to be replaced, it is unrestricted anyhow, I assumed the gt spec exhaust was a CBE setup, so that coupled with the invidia DP would be a tbe essentially.
Matthew
post #9 of 25 Old 09-11-2007, 01:37 PM
You are right. I missed where he listed his mods. I clicked on his car in his profile and everything is stock in there.
Get a good tune and you will hit 240 whp easily. It isn't about the HP though it is the TQ that you want. I would rather have 100 WHP and 400 TQ any day of the week.
Kjott21 is offline
post #10 of 25 Old 09-11-2007, 02:09 PM
you wouldn't want to drive that car. With that much torque and so little HP, it would have a very very low curve. It'd drive like shit and you'd spend more time shifting than accelerating.
post #11 of 25 Old 09-11-2007, 02:23 PM Thread Starter
thanks for all the help guys. keep the suggestions coming
achavez is offline
post #12 of 25 Old 09-11-2007, 02:59 PM
VD5505's Avatar
i think he would hit that very easy, i have an 03 and i just got back from chicago and i dyno out at 256lb ft tq, and 240 hp and i had a pro tune with TBE and uppipe crank pulley and AEM intake on it, and AEM wideband, i really thought i could of made a little more out of it but i guess not, do those numbers sound right to you guys????
VD5505 is offline
post #13 of 25 Old 09-11-2007, 10:56 PM
numbers mean nothing unless you tell us what kind of dyno you are using. that car would dyno around 210- 215 awhp on our dyno, Its a Mustang. a stock STI dose around 220.
nagyhead is offline
post #14 of 25 Old 09-12-2007, 07:13 AM Thread Starter
im lookin into two different tuners and they are both using the mustang dyno
achavez is offline
post #15 of 25 Old 09-12-2007, 09:48 AM
no way will it see 240 on a mustang dyno, without a turbo upgrade. a hella good tuner will get you 220.... mabey
nagyhead is offline
