2006 Wrx stage 2 question - Page 4 - Subaru WRX Forum
post #46 of 63 Old 01-08-2013, 07:30 AM Thread Starter
06_hawk_eye's Avatar
06_hawk_eye is an unknown
Can you explain excstly what that is?
Sent from my iPhone using AutoGuide.com App
06_hawk_eye is offline
post #47 of 63 Old 01-08-2013, 11:11 AM
See here:
GrimmSpeed
And here for a little more detail:
Porting and polishing. Get spooled faster! Hold boost to redline better! Creep less! - Subaru Forester Owners Forum
post #48 of 63 Old 01-13-2013, 04:43 PM Thread Starter
What's up guys well I emailed cbrd in York to get a price for install and tune on everything . Turbo injectors fuel pump intercooler tgv delete and air pump delete. Question for everyone out there. If I would install everything my self. Could I get a map to install that would make it safe to drive to the tune. Which is only 30 mins away.
Thanks
post #49 of 63 Old 01-14-2013, 05:50 AM
They would probably send you a limp map prior to heading their way. Talk to your tuner.
post #50 of 63 Old 01-14-2013, 12:04 PM Thread Starter
Anybody in the Lancaster pa area down to help me install turbo injectors fuel pump, top mount , turbo inlet . Food and drinks included along with cash. Let me know.
post #51 of 63 Old 01-14-2013, 01:22 PM
What inlet did you get? Silicone or hardpipe?
post #52 of 63 Old 01-14-2013, 01:24 PM Thread Starter
Perrin pretty sure it's silicone
post #53 of 63 Old 01-15-2013, 08:22 PM Thread Starter
Going with 780cc injectors my tuner uses them so I'm gonna go with them instead of the 650cc ones.
post #54 of 63 Old 01-18-2013, 06:52 PM Thread Starter
Well guys I installed my catback today ended up getting a cheap one of amazon it's an m2 exhaust full 3 inch with stock looking muffler but ts
Straight thru design. Bolted right up to my helix catted downpipe. The only problem is it touches my rear bumper I'll be ordering some longer exhaust hangers tonight.
post #55 of 63 Old 01-18-2013, 08:58 PM
Ack. You're going to be replacing that exhaust shortly. Those are known to rust. I've seen pictures of a relatively new one that rusted right off the hangers.
post #56 of 63 Old 01-21-2013, 07:03 PM Thread Starter
Heard all over the place that the Injectors on the 06 Wrx injectors are 565cc when I upgrade to
My vf43 I know it all depends on my final power goal. But if I were to stay with 565 injectors and just upgrade the fuel pump will I still be around 280-300whp. With my other supporting mods. Thanks guys
post #57 of 63 Old 01-22-2013, 05:41 AM
Maybe 280. The limiting factor will be the injectors.
post #58 of 63 Old 01-22-2013, 09:45 PM Thread Starter
I'm okay with 280whp and with similar torque. The money can be spent else where like full Perrin suspension. Front and rear sway bars
Sent from AutoGuide.com App
post #59 of 63 Old 01-23-2013, 05:35 AM
Research endlinks as well. Some bars don't play nice with some endlinks.
post #60 of 63 Old 01-23-2013, 10:43 AM
Very true - I was unable to get Kartboy's front endlinks to work with a Whiteline 24 mm adjustable front sway bar. I even tried to use the optional spacers, but it just didn't quite line up right, so I kept my stock front endlinks. However, I had no problems fitting Kartboy's rear endlinks with Whiteline's 22 mm adjustable rear sway bar.
The difference between stock and aftermarket sway bars is incredible!
