2.5 swap - Page 3 - Subaru WRX Forum
post #31 of 45 Old 09-30-2007, 10:50 PM Thread Starter
05WRXRally's Avatar
05WRXRally is more helpful than not
Well thanks for all the input guys, Now i know what i gotta do, any opinions on the turbo? I looking at the TD06 or a 30R
When the green flag drops...the bullshit stops
05WRXRally is offline
post #32 of 45 Old 10-01-2007, 04:42 PM
wrxman420's Avatar
It is all personal preference, how much power are you looking for? After taking a ride in my friends 35R 1G GSX, i know what im getting! His car is sick, once that turbo spools, it throws you back in your seat.
wrxman420 is offline
post #33 of 45 Old 10-01-2007, 04:58 PM
Ohh yea it does.. However for it run properly you really need a lot of suporting mods which = $$$$$$$$$$.. Trust me I know.. But MAN does that thing spool....
post #34 of 45 Old 10-01-2007, 10:32 PM Thread Starter
05WRXRally's Avatar
I want some power but not to much$$$$ while still keeping fuel economy. Just a step above an sti looking around 300-350 whp
post #35 of 45 Old 10-02-2007, 02:18 PM
Then I would say the stock location gt30r setup.. It is a little bigger then the 06 which will give you more more to grow latter on should you be able to afford it. It will also give you a little better MPG.. A larger turbo will not spool as soon and thus you will be in boost less often in your daily commute so your mpg will go up.. I was getting 31mpg with my GT35r putting down 425whp on the high way at 80mph..
post #36 of 45 Old 10-02-2007, 05:20 PM
wrxman420's Avatar
What could be better gas mileage and more power!
post #37 of 45 Old 10-02-2007, 05:33 PM
less lag?
post #38 of 45 Old 10-02-2007, 08:01 PM
As always, Mr Positive.. Lag .. Downshift..
"There is no such thing as Lag, Power is always a downshift away..."
post #39 of 45 Old 10-02-2007, 10:31 PM Thread Starter
05WRXRally's Avatar
That is so true! Damn 31 mpg? I get 24 city and i still boost about 9 psi
post #40 of 45 Old 10-04-2007, 08:44 PM Thread Starter
05WRXRally's Avatar
So i looked up all the main components i need, this does not include all the sensors and supporting PCM modules, injectors etc...
STi Shortblock- 1,600
STi Type RA gearset- 1,500
Hyperflow TMIC- 900
Deadbolt TD05 18g- 1300
Radiator- 500
So with all supporting modules, fuel components, and a tune, i think it will come out to about 7000 all together, im starting to think i should just save up for an STi, but im basing it on what condition everything else will be at, interior suspension, body, etc...
post #41 of 45 Old 10-04-2007, 08:51 PM
What sensors??
Granted it's not a bad idea to change the Crank and Cam sensors (about 150 total) but you don't have too..
The block is 1600
Gasket kit is 200 (I got mine cheaper)
post #42 of 45 Old 10-04-2007, 10:31 PM Thread Starter
05WRXRally's Avatar
Ya pretty much, with the MAF, a new EGR, PCV, ECT, Water pump, belts, all the externals
post #43 of 45 Old 10-30-2007, 03:58 AM
Fabian is an unknown
Wow, this is freaken interesting. So what does the labor cost, not including the engine, to swap in a 2.5 and swap out the EJ20??? What years to what years are compatible???
Fabian is offline
post #44 of 45 Old 10-30-2007, 10:39 AM
Jave's Avatar
Jave is more helpful than not
anything you want since you have to get a custom tune. Just remember you are reusing the timing and heads off of the 2.0.
▼SbiΣ Mi▼
Jave is offline
post #45 of 45 Old 10-30-2007, 10:36 PM
I'm glad all 06+ cars have the AVACS...less headaches. But of course we come with 2.5s as well.
