07 wrx - Subaru WRX Forum
post #1 of 5 Old 10-21-2007, 02:43 PM Thread Starter
wrxxx14 is an unknown
07 wrx
has anyone put TBE on with out a tune and got over boost do to no cats??
wrxxx14 is offline
post #2 of 5 Old 10-21-2007, 02:46 PM
SWFL Scooby's Avatar
SWFL Scooby is an unknown
Cold weather will cause boost spikes. Being in Jersey, this may happen in the winter months when you get on it. You can either get engine management or a catted downpipe, both of which will prevent spike and creep.
D-Rock
Under constant pressure
SWFL Scooby is offline
post #3 of 5 Old 10-21-2007, 02:57 PM Thread Starter
what about a diffrent restrictor pill. i heard that was a prob but i wasnt sure if it was only with stage 2... and one more question. i know everyone hates them but i have a bov on my car. will that hurt the cat?
wrxxx14 is offline
post #4 of 5 Old 10-21-2007, 03:15 PM
I wouldn't mess with the restrictor pill unless you are running high amounts of boost on an upgraded turbo. Engine management can be relatively inexpensive (tactrix, opensource) and is the safest way to go. The BOV does not effect the cat, but it will give your ECU an inaccurate reading of how much airflow is in the system causing you to run rich, especially between shifts.
D-Rock
post #5 of 5 Old 10-22-2007, 01:54 AM
Cobbs site says to change the line and pill to help solve for this problem regardless of what turbo you are running. If you go to thier site and find that bulletin it tells you what part number to get for you car.
