06 wrx turbo question - Subaru WRX Forum
post #1 of 24 Old 08-29-2012, 01:33 AM Thread Starter
Doble9 is an unknown
i got a 06 wrx i have already installed an aftermarket intercooler and full turbo back exhaust and am looking to up grade my turbo this is my first wrx and would like some suggestions and tips on ### kind of turbo and the install process thanks for the help
Doble9 is offline
post #2 of 24 Old 08-29-2012, 05:17 AM
What type of engine management are you using?
post #3 of 24 Old 08-29-2012, 07:08 AM
You will also need more than just a turbo. You will need at least a higher flowing fuel pump and injectors. What intercooler are you using, and what are you looking for/what are your goals for the car?
post #4 of 24 Old 08-29-2012, 08:56 AM
BoostinChick is a helpful contributing member
^ Depends on what turbo the OP is going with. If it's a VF, the injector size and what not are the same as the STi and a 145lph pump, so from a fuel perspective would be fine. But knowing the goals as you pointed out would be a good start in order to help.
- Sandra
2007 WRX TR | Stage 2 | PAR Gearset (Built by AndrewTech)
BoostinChick is offline
post #5 of 24 Old 08-29-2012, 03:04 PM
Well if he doesn't have EM then none of that matters...
post #6 of 24 Old 08-29-2012, 07:33 PM
IIRC, the WRX and STi pumps of old were a little different on flow.
post #7 of 24 Old 08-29-2012, 08:25 PM
The injectors are different...I've never heard about the pumps being different.
post #8 of 24 Old 08-29-2012, 10:43 PM
^ Ditto.
post #9 of 24 Old 08-30-2012, 05:39 AM
2 different part #'s from what I remember. Let me see what I can dig up in the near future.
post #10 of 24 Old 08-30-2012, 07:53 AM
The 06/07 had some of the best/highest flowing injectors (not sure now). They can easily be maxed out on a stage 2 tune. So if he wanted the injectors to be his limiting factor, he wouldnt have to change them out you are right. But on my little td04 I was able to max them out with just a full TBE.
post #11 of 24 Old 08-30-2012, 02:06 PM
From research I have done, stock vs. stock they are higher flowing. If you take the older injectors and mod them (remove the cap) people have seen between ~740-850cc. Never hurts to upgrade your fuel if you have the proper tools to manage it.
- Sandra
post #12 of 24 Old 08-30-2012, 06:08 PM
post #13 of 24 Old 08-30-2012, 06:55 PM
post #14 of 24 Old 08-30-2012, 07:36 PM
True cept the FP
post #15 of 24 Old 08-30-2012, 08:18 PM
Whats going on here, whos riding around without EM?
