-   -   06 wrx turbo question (http://www.wrxtuners.com/forums/f75/06-wrx-turbo-question-32955/)
Doble9 08-29-2012 01:33 AM
i got a 06 wrx i have already installed an aftermarket intercooler and full turbo back exhaust and am looking to up grade my turbo this is my first wrx and would like some suggestions and tips on ### kind of turbo and the install process thanks for the help
psinuse 08-29-2012 05:17 AM
[quote=Doble9;284845]i got a 06 wrx i have already installed an aftermarket intercooler and full turbo back exhaust and am looking to up grade my turbo this is my first wrx and would like some suggestions and tips on ### kind of turbo and the install process thanks for the help[/quote]
What type of engine management are you using?
newtothegame 08-29-2012 07:08 AM
You will also need more than just a turbo. You will need at least a higher flowing fuel pump and injectors. What intercooler are you using, and what are you looking for/what are your goals for the car?
BoostinChick 08-29-2012 08:56 AM
^ Depends on what turbo the OP is going with. If it's a VF, the injector size and what not are the same as the STi and a 145lph pump, so from a fuel perspective would be fine. But knowing the goals as you pointed out would be a good start in order to help.
psinuse 08-29-2012 03:04 PM
Well if he doesn't have EM then none of that matters...
pzr2874 08-29-2012 07:33 PM
IIRC, the WRX and STi pumps of old were a little different on flow.
turmic 08-29-2012 08:25 PM
The injectors are different...I've never heard about the pumps being different.
man show 08-29-2012 10:43 PM
^ Ditto.
pzr2874 08-30-2012 05:39 AM
2 different part #'s from what I remember. Let me see what I can dig up in the near future.
newtothegame 08-30-2012 07:53 AM
[quote=BoostinChick;284863]^ Depends on what turbo the OP is going with. If it's a VF, the injector size and what not are the same as the STi and a 145lph pump, so from a fuel perspective would be fine. But knowing the goals as you pointed out would be a good start in order to help.[/quote]
The 06/07 had some of the best/highest flowing injectors (not sure now). They can easily be maxed out on a stage 2 tune. So if he wanted the injectors to be his limiting factor, he wouldnt have to change them out you are right. But on my little td04 I was able to max them out with just a full TBE.
BoostinChick 08-30-2012 02:06 PM
[quote=newtothegame;284928]The 06/07 had some of the best/highest flowing injectors (not sure now). They can easily be maxed out on a stage 2 tune. So if he wanted the injectors to be his limiting factor, he wouldnt have to change them out you are right. But on my little td04 I was able to max them out with just a full TBE.[/quote]From research I have done, stock vs. stock they are higher flowing. If you take the older injectors and mod them (remove the cap) people have seen between ~740-850cc. Never hurts to upgrade your fuel if you have the proper tools to manage it.
psinuse 08-30-2012 06:08 PM
[COLOR="Lime"]Well if he doesn't have EM then none of that matters... [/COLOR]
turmic 08-30-2012 06:55 PM
[COLOR="Pink"]Well if he doesn't have EM then none of that matters... [/COLOR]
pzr2874 08-30-2012 07:36 PM
[COLOR="White"]True cept the [/COLOR]FP
BLAZE2099 08-30-2012 08:18 PM
[COLOR="Pink"]Whats going on here, whos riding around without EM?[/COLOR]
