I want to make the suspension a bit better on my 06 wrx. as of right now its all stock, and i was just wondering some things that are relatively inexpensive that i could put on that would make big gains?
Well, you should be replacing your struts and tophats, but that's not really inexpensive. Down the line I'd recommend replacing as many of your suspension bushings as you can, though that's very expensive unless you do the labor yourself, in which case it's cheap.
Then you might benefit from a good set. Get ready to throw down AT LEAST $2K
