06 WRX Need help with Upgrades - Subaru WRX Forum
post #1 of 11 Old 12-09-2011, 10:30 PM Thread Starter
Roman777 is an unknown
guys is u could proved me with the best list of upgrades needed for my 06 wrx to put out atleast 350 wtq and atleast 350whp or more. And wich companys are the best thanx!
Roman777 is offline
post #2 of 11 Old 12-10-2011, 08:04 AM
For 350/350, you'll need an upgraded turbo w/ supporting mods... there are a number of different paths you could take to get there. This is a good place to get some solid background info on modding: Unabomber's Manifesto - NASIOC
post #3 of 11 Old 12-10-2011, 03:33 PM
What John said and you'd probably have to kill your spool up to actually get 350/350. I have 350/375 with a STI transmission though and a built engine. Two things that could potentially break on a 350/350-375 are the 5 speed gear set and the engine might have a piston/piston ring related failure. Its happened many times before.
post #4 of 11 Old 12-10-2011, 06:46 PM Thread Starter
wats the max i can push on the stock wrx trany?
Roman777 is offline
post #5 of 11 Old 12-10-2011, 10:36 PM
Stock power. The 02-07 WRXs have had their stock trannies blown with stock power levels. Some have broke at higher levels. Keith (aka psinuse) lasted longer than me, with probably a little more power. I rocked my 07 transmission with around 330-350 HP for about 18,xxx miles before I upgraded.l Upon opening my gearbox, my third gear was cracked, but was still working.
post #6 of 11 Old 12-10-2011, 11:35 PM
I'm still pretty sure mine is a bend shift fork I really do. I highly don't recommend trying to see if your trans will last with that much power though.
I don't wanna sound like an a$$hat, but have you ever driven a car with 350whp?
post #7 of 11 Old 12-11-2011, 08:45 AM
This is another valid point. 350 AWHP is a good chunk of power. Its well over double stock power levels, and makes the car a nite and day difference in just about every aspect.
post #8 of 11 Old 12-11-2011, 12:31 PM
Well, the 06-07s have a taller ratio than the 02-05s also. So, that plays a factor in there. More stress on the gears.
For 2002-2007 WRX:
5 speed manual- 1st- 3.454, 2nd-1.947, 3rd- 1.366, 4th- 0.972, 5th- 0.738, final ratio is 3.9 for 2002-2005 and 3.7 for 2006-2007
post #9 of 11 Old 12-11-2011, 01:07 PM Thread Starter
i driven my brother G37.(stock) and his friends sti (over 300) and another friends wrx(low mods)
Roman777 is offline
post #10 of 11 Old 12-11-2011, 05:06 PM
A stock G37 and 350+ WRX are apples and oranges apart from each other. Start small, get stage 1 on the car, its better for the car to begin with. Then get stage 2 and get used to that, then start doing your research and saving up for an upgraded turbo (and probably a transmission and possible engine build during and after adding more power).
post #11 of 11 Old 12-11-2011, 05:27 PM Thread Starter
check out my other post till me ### u think on that. thanx
Roman777 is offline
