06 WRX could this setup work? - Subaru WRX Forum
post #1 of 77 Old 12-11-2011, 04:25 PM Thread Starter
Roman777 is an unknown
on a stock turbo could i bolt on this things?
Process West Cold Air Intake 72mm
GrimmSpeed Ceramic Coated Uppipe
COBB Tuning Downpipe Catted Bellmouth
Greddy Racing Ti-C Cat Back Exhaust
GrimmSpeed HiFlow Exhaust Manifold Crosspipe Ceramic Coated
Cobb Tuning Blow Off Valve
and TUNE.
is this a good setup?
Roman777 is offline
post #2 of 77 Old 12-11-2011, 04:45 PM
Sounds like a good setup. Your factory exhaust manifold is not restrictive to the other mods you listed so the manifold isn't really necessary but wouldn't be bad.
post #3 of 77 Old 12-11-2011, 05:29 PM
I would do a TMIC before any work to the exhaust manifold. Also, don't bother with the crosspipe and not get the manifold itself PnP'd by Grimmspeed as well.
Bascially I would either:
Nix the crosspipe all together and add an aftermarket/STI TMIC
or
Get the exhaust manifold elbows ported and polished by grimmsped, and get their crossover pipe as well.
Also, add in a 3-port ebcs. Always good to have.
post #4 of 77 Old 12-11-2011, 05:30 PM Thread Starter
thanx any idea what it could put out after tune? estemat?
Roman777 is offline
post #5 of 77 Old 12-11-2011, 05:41 PM
Numbers depend on type dyno, type of gas, altitude, the tuner and a plethora of other things. If you google or look around you can find similar WRXs with that setup and a HP rating. With all that you will probably easily max out your stock injectors depending on how aggressively tuned the car is.
post #6 of 77 Old 12-12-2011, 09:58 AM
Roman777, you might be in luck... I'm planning to have my 07 WRX tuned this weekend at IAG Performance which has similar mods to what you listed:
Cobb AccessPORT V2
Cobb catted downpipe
Grimmspeed ported/polished/ceramic coated exhaust manifold w/ high flow crosspipe
Grimmspeed 3 port electronic boost control solenoid
HKS Hi-Power Carbon-Ti cat back
K&N drop-in panel filter
Perrin lightweight crank pulley
Turbo XS TMIC
Walbro 255 lph fuel pump
I'll report back with some numbers if everything goes as planned.
post #7 of 77 Old 12-12-2011, 05:58 PM Thread Starter
lol k thanx bro!
Roman777 is offline
post #8 of 77 Old 12-12-2011, 06:34 PM
265whp...I put in my $5.
post #9 of 77 Old 12-12-2011, 06:57 PM
mazzanic's Avatar
mazzanic is an unknown
^^ lets hope. Prob around that
mazzanic is offline
post #10 of 77 Old 12-12-2011, 07:48 PM
I'd have to look at my old dyno sheet to even venture some guesses. The TD04-13T will be the limiting factor with that setup though. Unless he just wants to spool the crap out of it and have it hit hard and early.
post #11 of 77 Old 12-12-2011, 10:17 PM
I was hoping for 230... stop getting my hopes up!
post #12 of 77 Old 12-12-2011, 10:44 PM
John, a stock 06-07 STI makes about 220whp on a mustang dyno. So, I'd have to think it'd be higher than 230. Probably 250-260whp. I still haven't looked at my old dyno plots.
Edit: I was about 250 with a Stage II protune and 266 with grimmspeed 3 port bcs and perrin tmic. Granted a VF39 flows more. But, I didn't have any sort of headers/crossover pipes. So, it'll probably be near 250 on the smaller turbo.
post #13 of 77 Old 12-12-2011, 10:48 PM
closer to 250 than 260...I think Ron's record for the TD04-13T was in the 270ish range and his turbo was pretty worked over...although that was on a 2.0L...I think between 245 and 253
post #14 of 77 Old 12-12-2011, 11:10 PM
Yeah, thats why in my edit I said probably closer to 250whp. Ron's stock turbo was ported and polished also.
post #15 of 77 Old 12-13-2011, 05:04 AM
You guys keep saying what I've already said....lol
