-   -   06 WRX could this setup work? (http://www.wrxtuners.com/forums/f75/06-wrx-could-setup-work-31742/)
Roman777 12-11-2011 05:25 PM
on a stock turbo could i bolt on this things?
Process West Cold Air Intake 72mm
GrimmSpeed Ceramic Coated Uppipe
COBB Tuning Downpipe Catted Bellmouth
Greddy Racing Ti-C Cat Back Exhaust
GrimmSpeed HiFlow Exhaust Manifold Crosspipe Ceramic Coated
Cobb Tuning Blow Off Valve
and TUNE.
is this a good setup?
Chase 12-11-2011 05:45 PM
Sounds like a good setup. Your factory exhaust manifold is not restrictive to the other mods you listed so the manifold isn't really necessary but wouldn't be bad.
RcrsWetDream 12-11-2011 06:29 PM
1 Attachment(s)
I would do a TMIC before any work to the exhaust manifold. Also, don't bother with the crosspipe and not get the manifold itself PnP'd by Grimmspeed as well.
Bascially I would either:
Nix the crosspipe all together and add an aftermarket/STI TMIC
or
Get the exhaust manifold elbows ported and polished by grimmsped, and get their crossover pipe as well.
Also, add in a 3-port ebcs. Always good to have.
Roman777 12-11-2011 06:30 PM
thanx any idea what it could put out after tune? estemat?
newtothegame 12-11-2011 06:41 PM
Numbers depend on type dyno, type of gas, altitude, the tuner and a plethora of other things. If you google or look around you can find similar WRXs with that setup and a HP rating. With all that you will probably easily max out your stock injectors depending on how aggressively tuned the car is.
man show 12-12-2011 10:58 AM
Roman777, you might be in luck... I'm planning to have my 07 WRX tuned this weekend at IAG Performance which has similar mods to what you listed:
Cobb AccessPORT V2
Cobb catted downpipe
Grimmspeed ported/polished/ceramic coated exhaust manifold w/ high flow crosspipe
Grimmspeed 3 port electronic boost control solenoid
HKS Hi-Power Carbon-Ti cat back
K&N drop-in panel filter
Perrin lightweight crank pulley
Turbo XS TMIC
Walbro 255 lph fuel pump
I'll report back with some numbers if everything goes as planned.
Roman777 12-12-2011 06:58 PM
lol k thanx bro!
psinuse 12-12-2011 07:34 PM
265whp...I put in my $5.
mazzanic 12-12-2011 07:57 PM
^^ lets hope. Prob around that
turmic 12-12-2011 08:48 PM
I'd have to look at my old dyno sheet to even venture some guesses. The TD04-13T will be the limiting factor with that setup though. Unless he just wants to spool the crap out of it and have it hit hard and early.
man show 12-12-2011 11:17 PM
I was hoping for 230... stop getting my hopes up!
turmic 12-12-2011 11:44 PM
John, a stock 06-07 STI makes about 220whp on a mustang dyno. So, I'd have to think it'd be higher than 230. Probably 250-260whp. I still haven't looked at my old dyno plots.
Edit: I was about 250 with a Stage II protune and 266 with grimmspeed 3 port bcs and perrin tmic. Granted a VF39 flows more. But, I didn't have any sort of headers/crossover pipes. So, it'll probably be near 250 on the smaller turbo.
basco 12-12-2011 11:48 PM
closer to 250 than 260...I think Ron's record for the TD04-13T was in the 270ish range and his turbo was pretty worked over...although that was on a 2.0L...I think between 245 and 253
turmic 12-13-2011 12:10 AM
Yeah, thats why in my edit I said probably closer to 250whp. Ron's stock turbo was ported and polished also. ;)
psinuse 12-13-2011 06:04 AM
You guys keep saying what I've already said....lol
