06 Sti Rollover - Page 2 - Subaru WRX Forum
post #16 of 24 Old 01-13-2010, 02:27 PM Thread Starter
02WRXbugeye's Avatar
ok if I get the STI TMIC do I need to get a pro tune? Im running stage 2 accessport right now. and what kind of gain will i be looking at.
02WRXbugeye is offline
post #17 of 24 Old 01-13-2010, 03:51 PM
You can use it with your stage 2 setup but you won't gain anything. You'd need a protune to see any gains. How much gain will you get? Well, you may want to do some other mods while you're at it. With the STi TMIC, a fuel pump, a decent 3-port BCS, and a good tune, you could see substantial gains across the powerband.
post #18 of 24 Old 01-13-2010, 08:16 PM
A new STI tranny usually runs around the $4K mark without DCCD. Just to put it into perspective. Then theres installation costs, probably upgrade the clutch/flywheel also and you would also need to buy a new short shifter if you had one for the 5spd.
post #19 of 24 Old 01-13-2010, 08:41 PM
VD5505's Avatar
If you can try and take all the suspension hubs and wheels and brakes off that thing. Maybe even try and take the whole rear end and diff out of it as well.
2003 WRX Hybrid build,
Brian
VD5505 is offline
post #20 of 24 Old 01-13-2010, 11:23 PM
you can't take the hubs, they're not compatible. You'd be replacing a whole lot of the drivetrain to switch to 5x114. You can take the brake calipers if you buy some 04 STi sized 5x100 rotors but you can't use the 05+ rotors on a WRX.
The rear diff if I recall is also not that simple. if you want the tranny and the hubs though, maybe you just go all out and pull the car's entire driveline. Not an easy swap though. You need lots of little things.
post #21 of 24 Old 01-15-2010, 09:52 PM
Or you can stop building a Fake STI and just buy the real thing.
post #22 of 24 Old 01-15-2010, 10:10 PM
wrxshotta's Avatar
the tranny, conrtol arms and brembos!!!
*REMOVED CONTENT*
Bench racing is against the rules here. "My mouth is faster than your mounth" type bullshit will get you banned quickly.
-mosc
wrxshotta is offline
post #23 of 24 Old 01-15-2010, 10:14 PM
wrxshotta's Avatar
I Will Not Double Post! I Will Not Double Post! I Will Not Double Post! I Will Not Double Post! I Will Not Double Post! I Will Not Double Post! I Will Not Double Post! I Will Not Double Post! I Will Not Double Post! I Will Not Double Post! I Will Not Double Post! I Will Not Double Post! I Will Not Double Post! I Will Not Double Post! I Will Not Double Post! I Will Not Double Post! I Will Not Double Post! I Will Not Double Post! I Will Not Double Post! I Will Not Double Post! I Will Not Double Post! I Will Not Double Post! I Will Not Double Post! I Will Not Double Post! I Will Not Double Post!
post #24 of 24 Old 01-15-2010, 10:22 PM
^completely agree nick
