-   -   06 Modds need opinion (http://www.wrxtuners.com/forums/f75/06-modds-need-opinion-28206/)
Boyswrx 02-17-2010 05:34 PM
Hey guys, im new to this forum
recently picked up a 06 wrx. my plans are to try and keep it as stock as possible considering its my everyday driver including canada's winters. my plans
1. spark plugs- NGK Laser Iridium- what do you think? good plugs yes no?
2.exhuast- all sounds aside what should i do for best performance. eg. header or cat back..
3. Blow off valve- wondering what ones the best for performance and noise. what is needed to tune your car afterwards.
4. Air intake- what is the best one and what do i need to do when im done installing
5. anythiny else?- should i consider fuel filter ect.??
Please let me know what you think.
Boy!Thumbs Up
allvolwrx 02-17-2010 06:51 PM
As I seem to be suggesting alot lately ACCESSPORT! [url=http://www.cobbtuning.com]CobbTuning.com - Home Page[/url] Best first mod you can do IMHO. You dont even need new plugs until 60k miles. When/if it's time just stick to what your owners manual suggest mabye one step colder. For exhaust get a bellmouth downpipe and whatever you like the sound of to complete your exhaust. You shouldnt need a bov. If you must get one it should be a bpv (recirculating). No need for an intake. The stock one is pretty well designed. If you want to hear it then just do the snorkus delete (free). If you really want a intake The only manufacturers of intakes that claim in writing not to cause any ill effects are:
a. TurboXS
b. APS
c. Perrin (based on personal email correspondance with Perrin)
d. K&N Typhoon (based on testing by nhluhr and testing by AaronWRX, both NASIOC members) These tests were performed on an STi and their effect on WRX A/F ratios is untested.
e. Cobb Tuning
f. SPT
As for anything els just make sure all your maintenance is up to date.
pzr2874 02-17-2010 06:55 PM
Here's one of my favs :
[url=http://forums.nasioc.com/forums/showthread.php?s=&threadid=533787]Unabomber's Manifesto - NASIOC[/url]
Read it, learn it, love it
Boyswrx 02-17-2010 07:12 PM
can i get a recirculation valve that has the same sort of noise as a BOV, what will an aftermarket BPV do for me?
for exhaust i am under the impression to get rid for the up pipe and down pipe cat. should i buy an after marker down and up pipe for this and if so which ones are good, cobb and what other names are their so i can check them out?
allvolwrx 02-17-2010 07:36 PM
You have no cat in the uppipe.
newtothegame 02-17-2010 08:03 PM
I am running well over stock power and still running stock heat range spark plugs with no problem, so dont even worry about spark plugs. I wouldnt even worry about an intake either, my tuner said I shouldnt have wasted my money on mine for my upgrade. As stated above you need some type of EM (engine management) if you want to add more actual power to the car. As far as the exhaust a good bellmouth will get you the most bang for the buck added with the EM. And I run the Cobb XLE BOV in "hybrid" mode, still recirculates air to keep the car happy, and when in high boost will vent to the atmosphere. Even then the BOV/BPV isnt needed until running HIGH boost as the stocker will usually hold to 20PSI. But Perrin makes a decent BPV that can be heard better than stock, Turbosmart GFB (Go Fast Bits) also make nice BPVs.
Boyswrx 02-17-2010 08:52 PM
im looking for a nice perr to m exhaust and a nice performance, nothing major cause you cant really get much from that but as for the BOV/BPV i am looking for the blow off "PSHHH" sound .
the air intake idea was for noise aswell
im not looking for crazy horse
queastions, who makes the best downpipe for the car
i am just looking for noise from the BOV shopuld i stick with the BPV but an aftermarket one?
RcrsWetDream 02-17-2010 10:55 PM
1 Attachment(s)
Your best bet for that would be getting a hybrid valve. They only vent to atmosphere under high load, so you maintain drive-ability under regular driving conditions. Your second best bet would be doing at least the snorkus delete, unless you really do want to do an intake and get tuned for it. I run the Perrin cold air on my 09, which appear to actually benefit from an intake compared to earlier models, and I can hear the "psshht" in car like I'm venting to atmosphere.
Boyswrx 02-18-2010 06:24 AM
who makes the hybrid hks?
pzr2874 02-18-2010 07:44 AM
^ Did you not read the link I sent ?
You answered your own question! HKS
newtothegame 02-18-2010 08:32 AM
Cobb, Turbosmart, and GFB probably make some of the best "hybrid" BPVs out there. As far as intake then go with either Cobb,Mode Racing, or SPT as they are pretty much like stock and you can get a heat sheild/box with it to kind of keep temps down. As far as "best" thats a matter of opinion. I honestly believe that Cobb makes one of the best ones out there, also the most expensive one. As long as you get a quality bellmouth designed DP you will be fine.
man show 02-18-2010 09:54 AM
[quote=Boyswrx;240499]Hey guys, im new to this forum
Boy!Thumbs Up[/quote]
First of all, welcome! I'm always happy to see another hawkeye around here.
1. I did a bunch of research on spark plugs a little while back and here's what I found: [url]http://www.wrxtuners.com/forums/f103/man-shows-spark-plug-info-27782/[/url]
2. For absolute best performance, get a bellmouth style downpipe, any 3" cat back, and equal length headers OR Grimmspeed PnP w/ high-flow crosspipe (although you'll lose the signature subaru boxer rumble if you get equal length headers - but to some, the performance gains are worth it... since you want to remain mostly stock, the grimmspeed pnp/coated option might be the way to go along with a nice tbe and stage 2 tune)
3. Honestly, don't worry about the blow off valve - atmospheric, hybrid, or full recirc. Just do the intake silencer delete (a.k.a. snorkus mod) and get a K&N or other drop in panel filter and call it a day.
4. See #3. Otherwise, if you MUST have an intake, get an SPT intake with a heat shield. I don't believe Cobb makes theirs any more, but I could be wrong or maybe you can find one somewhere if you look around.
5. If I were you, I'd just buy a nice turbo back exhaust and get a stage 2 tune and that should probably keep you happy for a while. That can be done on somewhat of a budget if that's a concern, or you can go all out and get some really nice equipment. Either way, I'd suggest that setup and try it out for a while while you save up because the next step above that is to upgrade your turbo (which means also a bigger intercooler, injectors, fuel pump, and usually some other goodies... and a tune)
Read the Manifesto and see if you have any other questions. And again, welcome!
In my opinion, Cobb makes the best downpipe for 02-07 WRXs and STis. Get the Street version with a high-flow cayalytic converter. You'll only lose several (5 +/-) hp because of it, but you'll remain slightly more legal, pollute less, etc.
Boyswrx 02-18-2010 11:35 AM
this is the plan from your info
1. snorkus delete
2. spark plugs- NGK laser iridium
3. cobb downpipe with high flow cat, bellmouth style
4. catback 3" system
5. hybrid BPV-HKS
VisiX 02-18-2010 02:33 PM
[quote=Boyswrx;240548]this is the plan from your info
1. snorkus delete
5. hybrid BPV-HKS[/quote]
You need some form of Engine Management to go stage 2, without it your car will not run well and you will not see gains from your new exhaust.
Boyswrx 02-18-2010 05:13 PM
what does stage 2 tuning actually mean...ECU?
