WRX Headlights - Subaru WRX Forum
post #1 of 9 Old 12-07-2007, 03:04 AM Thread Starter
WRX Headlights
Good day..
Is there a possible way of removing the clear lense cover from the headlight unit so that I am able to black chrome the unit inside which is currently the stock wrx headlight chrome?
Ive noticed there are clips that hold this in place but not sure if they have been glued together or something....
Its a bugeye.
Ive seen it on a few heavymodded wrs's like on turbo mags website and so on..
Cause getting a set of STI lights here is like chickens teeth.
any Ideas?
thanks
Ric
Ricsta is offline
post #2 of 9 Old 12-07-2007, 03:39 AM
hesh_one's Avatar
you can follow this.. pretty much the same..
HOW TO: Remove Amber lense from 02' headlights
hesh_one is offline
post #3 of 9 Old 12-07-2007, 09:56 AM
you should also put the lights back in the oven for 10-15 mins. after you paint them. it softens that goo so you can put the lens on much easier and it will form a better seal.
nagyhead is offline
post #4 of 9 Old 12-08-2007, 12:03 AM Thread Starter
NAGY!!!!!!!
YOUR AVATAR!!!! YOU BUGGER!!! THATS THE LOOK IM AFTER MAN!!!!!
Did you do yours as stated above or what???
You reply to most of my threads and I only realy had a good look now at your avatar!!
NICE ONE!!
Thanks folks! is that temp degreesC or F?
Ricsta is offline
post #5 of 9 Old 12-09-2007, 10:23 AM
yeah, i split them by outting them in the oven at 150 degrees F. After they wer split i painted the inner light housing with flat black engine enamal
nagyhead is offline
post #6 of 9 Old 12-10-2007, 02:27 AM
LeohMit's Avatar
Do what Nagy says!!! I did mine 2weeks ago & they turn'd out GR8!!! Feels good to do such an easy&cheap project & get these results!!!
LeohMit is offline
post #7 of 9 Old 12-10-2007, 10:15 AM
it is alot easier than it looks.
nagyhead is offline
post #8 of 9 Old 12-12-2007, 11:15 PM Thread Starter
Thanks all...
Bought the Black Chrome paint, Will be pulling the lights on the morrow and Ill keep you
all posted!
Maaan Im hell excited It makes the cab look nice n' fresh!
Ricsta is offline
post #9 of 9 Old 12-13-2007, 12:55 AM
good luck man, Like everyone said it really isn't that hard, make sure you clean up any silicon goo right away, otherwise that stuff will make a huge mess.
Robby
02 rex is gone.
I defected to an evo :)
Evo is gone :(
Now I got nothing.
WRXKidid775 is offline
