Switching to LEDS - Subaru WRX Forum
post #1 of 10 Old 03-16-2012, 10:55 PM Thread Starter
Ridge10's Avatar
Switching to LEDS
Im switching all my lights to LEDs, except I need to know which flasher/load resistor will work in my 2002 WRX for my turn signals? I should only need two right?
-Derek
Ridge10 is offline
post #2 of 10 Old 03-16-2012, 11:28 PM Thread Starter
Ridge10's Avatar
And has anybody upgraded all their bulbs to LEDs? Im looking on Superbrightleds.com and there is alot of choices. Does anyone have any input on which I should or shouldnt get?
-Derek
Ridge10 is offline
post #3 of 10 Old 03-17-2012, 08:19 AM
I have LED parking lights in my headlights... and that's as far as I've gotten
post #4 of 10 Old 03-17-2012, 08:35 PM
I have LEDs in my license plate bulbs. That's all that I've done. I got them from superbrightleds.com...but, I'd have to find the package they came in to find the bill to remember what exactly I got.
post #5 of 10 Old 03-18-2012, 05:37 PM
WrxCruising's Avatar
I have done all of my interior lights, huge difference.
WrxCruising is offline
post #6 of 10 Old 03-18-2012, 07:11 PM
How do you guys like them compared to a normal bulb setup?
post #7 of 10 Old 03-18-2012, 07:52 PM
I've only did it because it gives the high end lexus/infiniti/bimmer look. The only difference is that the bulb makes a brighter white on my license plate. Meh...the bulbs have the led resistor built into the bulb. So, there is no need to change anything but the bulb in my set-up.
post #8 of 10 Old 03-18-2012, 10:48 PM Thread Starter
Ridge10's Avatar
Have you put in any accent lighting or just replace all the bulbs? Is that including the dash?
-Derek
Ridge10 is offline
post #9 of 10 Old 03-20-2012, 01:12 PM
I just replaced the bulbs, the 2 map lights and the dome light. Each light has 6 very bright LED's on it. So there is 18 actual lights emitting from the 3 lights. Very bright enough so no need for any accent lighting. Everything else is stock lighting wise, but was looking at reverse lights since I changed the ones in my Legacy and like them.
post #10 of 10 Old 11-26-2012, 11:38 PM
Im switching all my lights to peimar lighting, except I need to know which flasher/load resistor will work in my 2002 WRX for my turn signals? I should only need two right?
Great choice it will save lot of money for you
Darbtai is offline
