Stock triple guages and...oil changes - Subaru WRX Forum
post #1 of 15 Old 05-30-2009, 03:32 PM Thread Starter
zmanoside's Avatar
zmanoside is a helpful contributing member
Well I dont know if this is the right place to post this but here it goes....So I admit to being lazy and not doing my own oil changes until today. I decided its time to start putting synthetic oil in and chose Mobil 1 and chose to do it myself because its a hell of alot cheaper and you dont have some jiffy lube douscher touching your baby. Well, I went to do this "simple" oil change and it turned out to be a learning experience. If you have subaru's triple gauge package option on your car, which I do, the temp gauge is actually oil temp, not coolant temp as I previously thought. There is a temp sensor that is integrated into the oil drain plug, which I also did not know of. The bolt for the drain plug/sensor is 27 mm size (huge) and it needs to be an open wrench so the sensor lead can be disconnected and lead through. A socket wont work. I just wanted to put this out there for someone who may come by and learn this stuff BEFORE doing it. It will save you a trip
12.7 @ 109
zmanoside is offline
post #2 of 15 Old 05-30-2009, 04:22 PM
I would think twice if you're using Mobil 1 5w-30. I hear that it thins to a 20 weight over a short period of time, and many have had problems that went away after switching oils. Try a heavier weight or switch to another oil in 3k miles. If you insist on using that oil, at least have a UOA done. Well worth $20 or so.
WReXd is offline
post #3 of 15 Old 05-31-2009, 09:17 AM Thread Starter
zmanoside's Avatar
I've heard nothing but good things about mobil 1 oil. What kind of problems are you hearing about?
12.7 @ 109
post #4 of 15 Old 05-31-2009, 12:56 PM
04paulieWRX's Avatar
04paulieWRX is an unknown
ive been using mobil 1 for 15k+ miles with no problems
04paulieWRX is offline
post #5 of 15 Old 05-31-2009, 08:13 PM
For those of you who don't have the oil temp sensor on your drain plug and change your own oil, I'd highly recommend getting one of these: FumotoValve.com - Engine Oil Drain Valve - the bast way to change oil
They make oil changes so much easier and less messy.
post #6 of 15 Old 06-01-2009, 12:00 AM
blk02wrx is an unknown
Send a message via AIM to blk02wrx
and make sure you replace your oil filter!
O2 PEARL BLACK WAGON with some modds
blk02wrx is offline
post #7 of 15 Old 06-01-2009, 01:35 AM
^ Yep, of course. I said "less messy," not "completely mess-free." There's really no way to get around the oil leakage when you remove the old oil filter - I just try to lift the drain pan off the ground and get it as close as I can when I take it off, but the fumoto valve is super convenient.
post #8 of 15 Old 06-01-2009, 11:07 AM
This reminds me, I need a new drain pan. The pressure valve or whatever you call it, is like the size of a pinhole. The oil backs up and overflows everytime. It sucks, and oil changes usually end in me dowsing the driveway in soap and spending 20 minutes hosing it down.
post #9 of 15 Old 06-01-2009, 10:47 PM
Fortunately for me, I have access to a garage with a painted floor, so my tiny oil spils and other messes are easy to clean up.
On a side note, I just ordered a 6 pack of those new blue Subaru oil filters from Fred Beans Parts Home Page with crush washers (which I don't need, but I don't think I had the option to order the filters without the washers) for $29.95 + shipping. Anybody find them cheaper anywhere else? I hope not
post #10 of 15 Old 06-01-2009, 11:00 PM Thread Starter
zmanoside's Avatar
Can anyone confirm or deny this? Or is it a fairytale. My car feels smoother by the way, after the switch from conventional to synthetic. Lower operating temps. I'm stoked on it. No more Jiffy Lube for me EVER. I was suprised to see how small the oil filter was. Which I also got a Mobil 1 filter...
12.7 @ 109
post #11 of 15 Old 06-02-2009, 03:58 PM
My tuner asked me what oil I used before he flashed me to stage 2. I told him Royal Purple, he was like good because if you used Mobil 1 he was going to give me a warning about using that oil. I didn't ask him the details about it though. I know ive been using royal purple since 15000 miles on the car. It now has 34000.
post #12 of 15 Old 06-03-2009, 10:17 AM
I kept the stock oil from the factory in my engine only for the break in period (0 to 3,000 miles). Then I used Redline from 3,000 to 21,000 miles. Then I switched to Royal Purple at 21,000 miles and I'm just about to hit 34,000 too. I don't plan to switch again any time soon. Royal Purple makes good stuff.
post #13 of 15 Old 06-03-2009, 10:34 AM
i used mobil 1 for nearly 60000 miles and havent had one problem.
nagyhead is offline
post #14 of 15 Old 06-04-2009, 09:22 PM
1sxysubi is an unknown
I just put Mobile 1 in yesterday. Can hear it running smoother... Any one else hear any bad things????
1sxysubi is offline
post #15 of 15 Old 06-05-2009, 01:12 AM
jed344's Avatar
jed344 is an unknown
ran mobile 1 in my rsx for 2 years and am running it my wrx now with no problems
jed344 is offline
