STi rev setting - Subaru WRX Forum: WRX Forums
» Auto Insurance
Go Back   Subaru WRX Forum: WRX Forums > WRX Tech Forums > Non-Performance Tech
Old 07-05-2008, 07:15 PM   #1 (permalink)
zmanoside's Avatar
Timeslip: 9.999 @ 109.674
Reputation: zmanoside is a helpful contributing member
STi rev setting
Hey guys. I was looking through the owners manual and I discovered this REV setting for the STi. Well the manual says you can set the rev limiter from 2-7500 rpm. Well, for some reason my display wont let me set it past 7000 rpm, I'm just wondering if this is a typo in the manual or what???
12.7 @ 109
Offline   Reply With Quote
Old 07-07-2008, 03:09 PM   #2 (permalink)
zmanoside's Avatar
Nobody here could answer this question. I went on NASIOC and found the answer but I couldnt delete this thread mosc. Thanks.
12.7 @ 109
Old 07-07-2008, 04:18 PM   #3 (permalink)
mind posting the answer so if anybody has the same question they can search through and find it?
BTW, after a long conversation with my tuner, the rev limiter on my STi is now set to 7000rpms. He advises against any higher and the power band of my car (most STi's) is well out of that range anyway. The 2.5L works better shifting at around 6000 than it does at 7000. You'll go faster and be easier on your engine.
04 STi 16G powered lagless fun
04 WRX: SOLD
Old 07-07-2008, 04:30 PM   #4 (permalink)
zmanoside's Avatar
Ya, I was just getting confused/reading the manual wrong basically. The setting adjustment is for the shift light not the engine rpm cuttoff. After several responses, people also reccomended setting the shift light at 6k rpm, so I went with that.
Cheers, Zach
12.7 @ 109
Old 07-07-2008, 04:38 PM   #5 (permalink)
How do you set the shift light anyway? I've been meaning to do that...
04 WRX: SOLD
Old 07-07-2008, 05:07 PM   #6 (permalink)
zmanoside's Avatar
Turn the key to right before the car starts (the gauges will illuminate), dont start the car.
turn the rev thingy once and you will hear a beep. Look to where it normally shows outside temp and it will give you a number, i.e. 60, 45, (meaning 6,000 rpm, 4,500 rpm respectivley) use the rev knobby thingy on the left and turn it to the right or the left to set the light (your rpm gauge will actually follow the number you are setting)..after 3 seconds or so of not touching it, it will set. Then it will go to the audible shift beep, and you have a choice of on or -- (off). I'm pretty sure this (the audible shift beep) was a "new" feature on the 05 STi's though mosc.
12.7 @ 109
Old 07-07-2008, 08:45 PM   #7 (permalink)
great... I'll have to dig through the manual. Fortunately, I think the WRX and WRX STi manual in 04 were exactly the same and I kept my WRX's manual so hopefully it covers it.
04 WRX: SOLD
Old 07-08-2008, 02:28 PM   #8 (permalink)
Reputation: turmic is a WRX expert worth listening to turmic is a WRX expert worth listening to turmic is a WRX expert worth listening to
Strange i set mine to almost 7k. I don't get a beep. Just the flashing little light on the dash.
Old 07-08-2008, 07:57 PM   #9 (permalink)
zmanoside's Avatar
AFTER you set the rpm and you let it set it will go to the beep setting which will show -- or off and on. Use the rev knob and turn it to the right or left to turn it off or on.
Z
12.7 @ 109
Old 07-28-2008, 01:53 PM   #10 (permalink)
I changed it to the beep setting a while ago...but just now decided to comment again. Nice little bit of info. z
Old 07-28-2008, 04:27 PM   #11 (permalink)
I tried ####ing around with it and didn't get very far. I hit the trip button and 00 comes up. Then I turn the rev nobby and nothing happens. Thoughts?
04 WRX: SOLD
Old 07-28-2008, 04:32 PM   #12 (permalink)
zmanoside's Avatar
You dont have to hit the trip button at all. The instructions says to have the car key in the lock position, which is false, it also says you have to press the trip button, which is also false. Turn the key to the on position, dont start the car, just turn the rev knob and you should hear a beep and be able to set it.
12.7 @ 109
Old 07-28-2008, 04:33 PM   #13 (permalink)
Man, I feel lied to and manipulated!
EDIT: Well, I tried that and it didn't do anything.
04 WRX: SOLD
Old 07-29-2008, 07:32 AM   #14 (permalink)
It didn't at least set your rev limit w/o a beep? Because I thought that zmanoside said you could still set the rev limit. Just no beep, because the 04s didn't have the beep option. After you set the limit. I just turned the knob right again....i believe and it beeped. turning on the beep option when i hit the rev limit.
Old 07-29-2008, 07:55 AM   #15 (permalink)
zmanoside's Avatar
I dont know what to say mosc. I went out to my car just to verify everything I said was correct and it worked fine....Z
12.7 @ 109
