Stage 2, passing inspection. - Subaru WRX Forum
 1Likes
  • 1 Post By Ruso
post #1 of 15 Old 10-29-2016, 02:26 PM Thread Starter
Brad Evans's Avatar
Will I pass inspection with catless downpipe, no check engine light but used to throw codes before tuner was on.
Sent from my SM-G900P using Tapatalk
Brad Evans is offline
post #2 of 15 Old 10-29-2016, 02:38 PM
Ruso's Avatar
Depends on inspection. Over here in Washington, they simply plug into the OBDII port and scan for engine codes (making sure that all sensors had time to collect data).
There is no smog test or anybody looking under the hood looking for modifications or anything.
If that's the case where you are then you should be good if you don't trigger codes but it depends on how they do it over where you are.
Ruso is offline
post #3 of 15 Old 10-29-2016, 02:49 PM Thread Starter
Brad Evans's Avatar
They do it the same over here, plugged in obd2 here and plugged in gas cap.
post #4 of 15 Old 10-30-2016, 01:37 PM
arcticscythe's Avatar
If you live in a CARB state a catless downpipe will fail the sniffer test. Most inspection stations do not have the technology to check your ECU tune but they do check for outward symptoms of an excessivly polluting car. If everything looks buttoned up and your tune is not throwing check engine codes you should be ok unless you are in a CARB state.
- Jason
arcticscythe is offline
post #5 of 15 Old 10-30-2016, 10:03 PM Thread Starter
Brad Evans's Avatar
Throwing only code p0442 small evap leak
post #6 of 15 Old 10-31-2016, 09:12 AM
Well for me, I failed at the local inspection station. I have a Invidia Catless downpipe and a v3 accessport. Cleared all the codes before inspection but still ended up failing. Here in NJ they just run the OBDII scanner but i still ended up failing.
Jay R K is offline
post #7 of 15 Old 10-31-2016, 09:18 AM Thread Starter
Brad Evans's Avatar
You can't clear codes before you go there because none of the readiness monitors will be set
post #8 of 15 Old 10-31-2016, 11:19 AM
Ruso's Avatar
Just thought of something, you can't simply clear codes but you can disable them.
You have an AP which will let you do that, no clue how to do it on AP but that could be a temp fix if you just need to pass. You still have to drive around to get enough data since at least on Tactrix changing the map resets ecu.
Ruso is offline
post #9 of 15 Old 11-01-2016, 05:47 AM
RogueMantis's Avatar
I believe you have to use AccessTuner to permanently clear the codes and re-flash whatever tune you are running.
06 WRX - Cobb Stage 2
RogueMantis is offline
post #10 of 15 Old 11-01-2016, 07:42 AM
GSMNZ's Avatar
I created a tune to force readiness monitors instantly. If you have AccessRace Tuner then you can do the same. If you don't see if you can locate someone with a 02 Version of the program.
GSMNZ is offline
post #11 of 15 Old 11-01-2016, 07:44 AM
GSMNZ's Avatar
Mind you this is not a permanent tune I use. Its just one I flash before getting an inspection an then a flash back to my stage 666 tune.
GSMNZ is offline
post #12 of 15 Old 11-01-2016, 08:12 AM Thread Starter
Brad Evans's Avatar
I have a v3 ap
post #13 of 15 Old 11-01-2016, 08:47 AM
GSMNZ's Avatar
Every year has a specific program. I didn't mean the V2 app I mean the AccessRace Tuner Program for the Model year 02. Like my version is for 05 its not capatible with your AP even tho both of ours are V3.
GSMNZ is offline
post #14 of 15 Old 11-01-2016, 02:22 PM
Ruso's Avatar
Lol @ stage 666!
Brad Evans likes this.
Ruso is offline
post #15 of 15 Old 01-04-2017, 09:17 PM
ink
if you live in a place that does a visual inspection your DP could fail for missing a cat but even in states that are supposed to check that they dont always do it
ink is offline
