speakers w/ factory grilles? - Subaru WRX Forum
post #1 of 3 Old 11-12-2003, 01:39 AM Thread Starter
stevewrx is an unknown
Question speakers w/ factory grilles?
I have seen numerous posts on speakers, but I would like to know whether I can fit larger speakers behind the factory grilles in my '04, even if they have to be shimmed out to avoid hitting the window glass
I would consider 5 1/4" or 6 1/2" component speakers
Also, has anyone mounted new tweeters in the pods above the door handles? I would like to install a component setup with a factory look.
stevewrx is offline
post #2 of 3 Old 11-12-2003, 06:18 PM
03slvsubie's Avatar
03slvsubie is an unknown
larger speakers will work fine but you have to have a spacer between the door and the speaker to fit. I am going with a Infinitys 6000cs componet system for the fronts. they are only 1 7/8 deep which is the skinnest i have found. they still need a spacer though since you only have about 1 3/4 of room before the window. http://www.iaperformance.com/catalog...&catalogArea=1 this is the site you want to buy the spacers from.
jeff
03slvsubie is offline
post #3 of 3 Old 11-14-2003, 09:53 AM Thread Starter
Thanks, These will fit behind the factory grilles?
Also, have you installed the tweeters?
stevewrx is offline
