speaker spacer - Subaru WRX Forum
post #1 of 9 Old 08-23-2005, 11:13 AM Thread Starter
silver02wrx's Avatar
silver02wrx is an unknown
speaker spacer
Im getting new speakers and Im still not exactly sure how to make a spacer and where it fits on the speaker. Can someone help me out how to make one and put one on? Ive heard Mazda spacers would work????
silver02wrx is offline
post #2 of 9 Old 08-23-2005, 05:16 PM
Jave's Avatar
Jave is more helpful than not
http://tmz.com/wrx/fspeakers.html
foudn this about 3 months ago when I was looking at upgrading myself. Hope it helps.
bottom has a pattern downloadable in PDF format.
Jave is offline
post #3 of 9 Old 08-28-2005, 12:47 AM
Ali G's Avatar
Ali G is an unknown
What you need is called a baffle... you can make them yourself out of MDF. You make rings for the speaker to fit in. The speakers should give you a mounting diameter which will tell you how big to make the inside circle of the ring, then you just make the outside a little larger than the basket of the speaker so it can be screwed into the metal door frame.
Ali G is offline
post #4 of 9 Old 08-29-2005, 12:52 PM
Nose Nuggets's Avatar
i wonder how much space there is between the speaker section of the plastic door cover and the steel door itself. my new door speakers are about 5" deep....
Nose Nuggets is offline
post #5 of 9 Old 08-30-2005, 10:24 AM
CanadianSub's Avatar
Images: 22
CanadianSub is an unknown
Send a message via MSN to CanadianSub
my nabour have a 05 impresza and he use 1 inch spacer with boston accoustic
CanadianSub is offline
post #6 of 9 Old 08-30-2005, 01:51 PM
cool
post #7 of 9 Old 09-02-2005, 02:10 PM
jeff04 is an unknown
Can I buy spacers for the front speakers somewhere? I really want to ditch the crappy factory speakers, they sound horrible.
jeff04 is offline
post #8 of 9 Old 09-06-2005, 06:22 PM
If anyone knows where to buy spacers for the front speakers, please let me know. Thanks.
jeff04 is offline
post #9 of 9 Old 09-07-2005, 05:49 PM
If you need speaker spacers go to Innovative Autosports.com.
jeff04 is offline
