Speaker size pleaze - Subaru WRX Forum
post #1 of 7 Old 08-10-2005, 03:02 PM Thread Starter
CanadianSub's Avatar
Images: 22
CanadianSub is an unknown
Send a message via MSN to CanadianSub
Speaker size pleaze
I want to change my car system and i need the speaker size on my 04 WRX and depth demenssion
Thanks
CanadianSub is offline
post #2 of 7 Old 08-10-2005, 03:15 PM Thread Starter
Images: 22
Originally Posted by 03slvsubie
the front ar 5 1/4 and the rears are 4. the max depth for the front is
1 3/4 and the rear is really deep since the window does not go all the way down. personally i would not mess with the rear deck, if you get the right speakers you won't need any in the rear deck.
jeff
ok find it sorry ....
or if it'S not right tell me cause im ordering ....
post #3 of 7 Old 08-10-2005, 06:41 PM
Ian
Ian's Avatar
Ian is more helpful than not
Send a message via AIM to Ian
I just got the Boston Acoustic speakers SL60 for my front doors (didn't put them in yet, slowly building stereo system) and the specs are 6 1/2 (160/165mm) mounting cut diameter 5 1/4 (134mm) mounting depth 2 7/16 (62mm). They are suposed to be a dirrect fit for the WRX/STI. The rear speakers are the same, hope this helps
Ian is offline
post #4 of 7 Old 08-10-2005, 07:20 PM Thread Starter
Images: 22
so you said speaker diameter is 5 1/4 and maximum depth his 2 7/16
post #5 of 7 Old 08-10-2005, 07:43 PM
Jave's Avatar
Jave is more helpful than not
any 5 1/4 will work as long as you have the ablility to make spacers if needed.
http://tmz.com/wrx/fspeakers.html
Jave is offline
post #6 of 7 Old 08-11-2005, 09:49 PM
Ian
Ian's Avatar
The speakers are 6 1/2 the mounting cut diameter 5 1/4 and yes the depth is 2 7/16 that in inches
Ian is offline
post #7 of 7 Old 08-18-2005, 08:11 AM
coombz24's Avatar
coombz24 is an unknown
Send a message via AIM to coombz24
if you go to crutchfield.com you can enter in your car and they will show you everything that will fit your car from spearkers to head units.
Dan
coombz24 is offline
