Speaker configuration - Subaru WRX Forum
post #1 of 11 Old 04-07-2013, 06:51 AM Thread Starter
Fidrat's Avatar
I recently took the front door card off to make another repair and I was horrified to see the crappy speakers Subaru gave me!:eek: No wonder this is the worst stock stereo I've ever heard. So I started to look for direct fit replacement speakers. My question is this...
Most replacement speakers are 2-way or 3-way. I assume the 2-way means bass/mid and a tweeter and 3-way means a mid cone+a bass cone+a tweeter cone. If I want a direct replacement in the front speaker shouldn't it just have a bass and a mid since the tweeter is separate?
Should I get a 3-way in the front and unplug the stock tweeter? I like the idea of a separate tweeter and I would like to keep it.
Will the signal coming from the head unit send a 3-way signal to the speaker or will it just be mid and bass making the tweeter on the speaker useless?
I haven't seen the rear speakers yet are they 3-way since I see no separate tweeter? Is there a 3-way signal going to them?
Fidrat is offline
post #2 of 11 Old 04-07-2013, 04:34 PM
dirtydeeds02's Avatar
dirtydeeds02 is an unknown
You can go either way. You wouldn't need to disconnect the tweet if you installed a 3way. Its more of a personal preference.
dirtydeeds02 is offline
post #3 of 11 Old 04-07-2013, 05:03 PM Thread Starter
Fidrat's Avatar
Pioneer TS-A1305C 5-1/4" component speaker system at Crutchfield.com FRONT
Pioneer TS-G1044R 4" 2-way car speakers at Crutchfield.com REAR
This is what I'm looking at getting. Does the stock front setup have a crossover? Where is it? should I remove it? Can I plug in the new crossover into where the stock crossover was if it has one?
Fidrat is offline
post #4 of 11 Old 04-08-2013, 06:55 AM
Those 5-1/4's will do just fine... The tweeter will have a capacitor on it (should). And the 5-1/4 does look like they have passive crossovers... not sure about that since I've always had a real crossover (depending on your music pref).
Are you thinking of running these speakers off the stock HU power>???
post #5 of 11 Old 04-08-2013, 05:37 PM Thread Starter
Fidrat's Avatar
Yes,I'm poor and old (still have CDs) I use the cassette player for an MP3 adapter.
Fidrat is offline
post #6 of 11 Old 04-08-2013, 07:58 PM
I'm not a fan of using factory 5.25" F and 4" R. Personally, I installed a component 6.5" system using provided brackets in my front doors. I gutted the factory tweeter and managed to fit the new one in the factory location with pretty much no room to spare. I then mounted the crossovers in the lower right portion of the door. I can't remember if I had to trim the metal on the door. I probably did. I also had to cut out the Styrofoam on the door card to clear the crossovers. Both the tweeter and crossovers had to be mounted with custom brackets. Unfortunately, I must have forgotten to take photos.
You can actually fit 6.5" coaxial (two way) in the rear if you trim a LOT of material. I used an air saw. It barely fit. I had to trim the plastic off the tweeter so the door card would sit flush. Is it worth putting a two way or such large speakers in? No, I don't think so. The location of the factory rear speakers are very poor. No matter what you do, it's going to sound like shit back there from the drivers perspective. This was my part time job at Best Buy, so I got the speakers for cheap and had plenty of down time to see what I could fit back there.
Rear door of a 2004 WRX. Outline to fit 6.5" Infinity Reference 2-way speakers.
Speakers installed after door cutting and water "proofing" with dynamat. Photo was taken before I realized I had to trim the tweeter.
Edit:
I just re-read your post. I should probably explain more. If what you mean by 3-way is separate base, mid, and tweeter speaker, I am unsure if you can fit oval type speakers in our doors. You may, but I personally have no experience with them. AFAIK, most people stick to component (separate tweeter) or coaxial (two way). If you go the separate tweeter route and you have factory tweeters (again, I'm pulling from fuzzy memory), I believe you have to gut part of the speaker wire. I think Subaru does it differently than aftermarket. You need the full signal which goes to a passive crossover. In this box, it filters the signals and sends a set to the tweeter and the other to the speaker (mid/base). That means you have to trace the wires far enough back to find where Subaru does its split. Hopefully, someone that's done this more recently than I have can chime in.
As for coaxial, the "crossover" is built in. No box needs to be mounted (not provided) and the wires from the HU just go to the speaker itself. Obviously, components will sound better than coaxial. But it also has a lot to do with tweeter location. Factory location of the tweeter is OK - not great.
post #7 of 11 Old 04-08-2013, 09:23 PM Thread Starter
Fidrat's Avatar
Pioneer ASeries 4" x 6" 3Way Car Speakers with Carbon Graphite IMPP Cones Pair TS-A4674R - Best Buy
This is what I mean by 3-way speakers. This is just an example, it shows a woofer,tweeter and a mid on the same speaker. I'm not thinking about putting these in. It's just to show you what I'm talking about.
Sorry,I don't feel like cutting anything (sheet metal) . I'm looking for a quick and easy plug and play fix.
Fidrat is offline
post #8 of 11 Old 04-08-2013, 09:45 PM
For the fronts, I'm fairly certain you don't need to cut. All you need are spacers.
post #9 of 11 Old 04-08-2013, 10:28 PM Thread Starter
Fidrat's Avatar
Unless It's easy to get at I doubt I will find Subaru's split. Does this mean, if I hook up the passive crossover that comes with the speakers to the wires that come from the head unit to the stock speakers it will make the passive crossover useless?
Should I forget about the crossover that comes with the speakers I'm looking at?
Fidrat is offline
post #10 of 11 Old 04-09-2013, 11:23 AM
Here, look at this first post. It's really easy to get to.
http://legacygt.com/forums/showthrea...iy-96931.html?
It depends how much you care about sound quality. Mine is amp'ed so I can defiantly hear a difference. If you're just using the HU built in amp, you will notice less of a difference.
post #11 of 11 Old 04-09-2013, 05:45 PM Thread Starter
Fidrat's Avatar
Oh,WOW!! That answers all my questions in one WHACK! Thank you very much! I bow down to your greatness!!!
Fidrat is offline
