Smoked Tail Lights - Subaru WRX Forum
post #1 of 12 Old 10-26-2012, 11:11 AM Thread Starter
Jautry27's Avatar
Jautry27 is an unknown
Smoked Tail Lights
I want to smoke out the tail lights on my 2007 WRX, but I wanted to get your opinions on a few different options. 1: Buy the paper,plastic( or whatever it is) and put it over the lights. 2: buy the plastic shade that more or less "sticks" to it. OR 3: Buy the spray on stuff, which is obviously the most cost efficient
OPINIONS?
Jason - 2007 WRX TR - Warning: Objects In Mirror Are Losing
Jautry27 is offline
post #2 of 12 Old 10-26-2012, 11:27 AM
ZincGT is an unknown
the VHT nightshades will fade after time, I took mine to an autobody shop and he did 2 coats of reduced black then a clear coat. The lights have a dark cherry look in the sun and any other time they look black. I love them
ZincGT is offline
post #3 of 12 Old 10-26-2012, 11:29 AM
BoostinChick is a helpful contributing member
Get 04/05 tails.
/thread
- Sandra
2007 WRX TR | Stage 2 | PAR Gearset (Built by AndrewTech)
BoostinChick is offline
post #4 of 12 Old 10-26-2012, 12:13 PM Thread Starter
Jautry27's Avatar
Originally Posted by BoostinChick View Post
Get 04/05 tails.
/thread
I found a set on NASIOC for $120 + shipping, but at this moment, I'm a little too poor. I'd have the money in a few days, but I'm sure they'll be gone by then.
Jautry27 is offline
post #5 of 12 Old 10-26-2012, 12:40 PM
rex2002's Avatar
check out my thread when i blacked mine out with vht. did back in 2010 and only re applied once since then(main reason b/c i wanted to go darker,but ZINCGT is correct it will fade a little) i blacked out my tail lights with vht
rex2002 is offline
post #6 of 12 Old 10-26-2012, 12:45 PM
Be long gone. That's a deal.
Get the vinyl. Check your local enforcement and see if they allow it. If you have inspections in Ga., stop by a shop and see if they allow it. If you cover your tails, your eliminating reflectors. I failed inspection because of it. The cops let it slide, but it's illegal.
If you do a vinyl, peel off and your good vs sanding and buffing for hours.
In a can, yes the spray is cheaper, but doing it the "right" way, is the most expensive.
post #7 of 12 Old 10-26-2012, 02:57 PM Thread Starter
Jautry27's Avatar
What's sad is that I am only $20 short of getting them. But since I have been replacing my engine, funds are VERY TIGHT.
Jautry27 is offline
post #8 of 12 Old 10-26-2012, 04:19 PM Thread Starter
Jautry27's Avatar
I think what I will end up doing is spraying them until I can afford to buy the actual lenses.
Jautry27 is offline
post #9 of 12 Old 10-26-2012, 04:39 PM
AllExtinct's Avatar
You might want to find something to do a few practice sprays.
I had old glass top end tables that I used to get the can control down.
This stuff is a real PITA to try to get off if you mess up.
Be warned that some pokey really don't like blackouts.
Good luck man.
Cobb Accessport Stage 2.
JDM ej205 swap.
Home state: PA Crew
Chuck.
AllExtinct is offline
post #10 of 12 Old 10-26-2012, 07:50 PM
My apologies for the glare, but here's an old pic of my 07 tail lights with a light smoke tinted vinyl film from HotSubarus.com. That website no longer exists, but a very similar product can be found at Lamin-X.com. Keep in mind that if you go with a vinyl tint, the film won't wrap all the way around the inner edges of the tail lights, so you'll see a little bit of chrome (2007), grey (2006), or red (2004/2005) if you look at the back of the car from any angle.
Tinted vinyl film is easily reversable if you get pulled over, but it is honestly pretty difficult to apply perfectly. You need a steady hand to make a clean cut with a razor around the edges and a lot of patience when you're pressing them on or you'll get wrinkles and/or bubbles. Temperature also causes the film to shrink just a little bit, so the edges will pull inwards ever so slightly, so if you're OCD, it might not be the product for you.
post #11 of 12 Old 10-27-2012, 06:40 AM
Would soapy water work with it John? Like window tint.
And would a heat gun be a good idea for the bends and whatnot?
post #12 of 12 Old 10-27-2012, 07:23 AM
Probably... I was fairly successful using just plain water in a spray bottle and a hair dryer. I only had to pop a couple of small bubbles in the middle of the lights and there was only one small stubborn wrinkle that kept popping up on the edge nearest the gas cap which I constantly had to push back down, but overall, I was happy the way everything turned out.
Here's another craptacular pic.
