Rim Cleaning Question - Subaru WRX Forum
post #1 of 4 Old 07-31-2005, 07:13 PM Thread Starter
2005Sti's Avatar
2005Sti is an unknown
Send a message via AIM to 2005Sti
I have the gold Sti stock rims. Now I spend about as much time cleaning them as I do the car when I wash it, problem is small black spots on them, generally in the rim grooves. Does anyone know how to get rid of these/or how to prevent them? Thanks guys...
2005Sti is offline
post #2 of 4 Old 07-31-2005, 07:55 PM
Ian
Ian's Avatar
Ian is more helpful than not
Send a message via AIM to Ian
Thats probably tar from the road, no real easy way to clean but you can try picking off the clump then useing a wax and grease remover or rubbing alcohol should work
Ian is offline
post #3 of 4 Old 08-01-2005, 03:15 PM
jwtarbaj's Avatar
Images: 11
jwtarbaj is more helpful than not
Wax the wheels every time you rotate your tires. Makes stuff come off much easier. Be sure to wax the inside part of the wheel as well as the outer area and try not to get any on the tires.
When they are waxed the grime/dirt/stuff will typically wipe right off. I do mine every 3-5K miles.
jwtarbaj is offline
post #4 of 4 Old 08-01-2005, 06:59 PM
Ian
Ian's Avatar
That would help but not all wheels have a clear coat on them, take mine for example they have a textured finish waxing them would be a disaster
Ian is offline
