Reverse lights always on - Subaru WRX Forum
post #1 of 2 Old 06-04-2010, 03:07 PM Thread Starter
Ridge10's Avatar
Ridge10 is an unknown
The reverse lights are always on in my 2002 wrx when I turn it on. I need to kno how to fix this or wear to look.
Ridge10 is offline
post #2 of 2 Old 06-04-2010, 04:44 PM
You probably have a defective reverse switch, driver's side of the transmission screwed to the case in the center of the main housing. If you disconnect it and the lights turn off then you probably just need to replace it. If that doesn't work then you have some crossed wires, can't really diagnose electrical issues on the internet so if that's the case save some money and find a good mechanic/electrician.
2009 STi - Cobb Stage 2
VisiX is offline
